One Piece RMS Paper Gasket - RTV? - Team Camaro Tech
post #1 of 5 (permalink) Old Sep 22nd, 16, 04:31 PM Thread Starter
Chad
cv2065's Avatar
Getting ready to install this one piece RMS again, and can't recall if I used any RTV on the Felpro paper gasket that goes to the block the first time around. I 'think' that I coated both sides with Permatex #2 (black), and then slid the seal housing up, but wanted to run it by you guys. Had no leaks the first time around, and want to continue the tradition. Thanks.
67 Black RS Coupe, 383, M21 & 10 Bolt Posi. Edelbrock E-Tech 170 Heads, 2204 Roller Cam, Air Gap Intake.
cv2065 is offline
post #2 of 5 (permalink) Old Sep 22nd, 16, 04:38 PM
Re: One Piece RMS Paper Gasket - RTV?
If its a paper gasket that the opposite side will likely be removed, I glue the paper down with 3M black or HiTack. If you feel the cover needs to be coated, you might smear rtv on it, just precaution.
I guess you are getting everything back together?
TC # 349
zdld17 is offline
post #3 of 5 (permalink) Old Sep 22nd, 16, 05:02 PM Thread Starter
Chad
cv2065's Avatar
Yep, crank, cam and pistons are all back in and getting ready to seal up the bottom end. Thanks for all the help Don!
cv2065 is offline
post #4 of 5 (permalink) Old Sep 22nd, 16, 05:12 PM
Kool, hope the pan gasket is one piece Felpro.
TC # 349
zdld17 is offline
post #5 of 5 (permalink) Old Sep 22nd, 16, 05:24 PM Thread Starter
Chad
cv2065's Avatar
Yes sir. It's a one piece but a Moroso. Very nice piece!
cv2065 is offline
