LS Engine Swap - Team Camaro Tech
post #1 of 14 (permalink) Old Sep 25th, 16, 01:22 PM Thread Starter
Gary
LS Engine Swap
Short back story....I've had my '69 for a long time and finally started redoing it a few years ago. I got it pretty much torn down (I'm really good at that but the back together goes slow) and the Ridetech coilover suspension in before we decided to move.
Now a couple of years later I'm ready for the LS1 engine swap with 4L60e trans. I've been researching and found mounts that keep the engine in the same place or move it forward or back. Is this for clearance depending on trans or for using different components? I was leaning toward the Hooker/Holley set up--any pros or cons? Most of the info I found was fairly old so I thought I would throw this out there. My car is a small block RS/SS with factory air if that matters. Thanks, Gary
narlee is offline
post #2 of 14 (permalink) Old Sep 25th, 16, 01:30 PM
Re: LS Engine Swap
The 1" set-back mounts keep the motor in the stock location...Dirty Dingo sliders are a great option to get it where you want/need.
Usually this is due to the options you're going to use.
68 Camaro~LSx ~all motor
post #3 of 14 (permalink) Old Sep 25th, 16, 01:46 PM
Re: LS Engine Swap
The Holley/Hooker solution is the way to go in my experience. Fully engineered mounts, accessory drive, trans crossmember, headers and exhaust that all work and fit together. It is also the only solution that allows the factory evap case to fit as far as I know. They tried to cover all the bases.
1959 El Camino project
1957 Buick Caballero project
dhutton is online now
post #4 of 14 (permalink) Old Sep 25th, 16, 02:38 PM Thread Starter
Gary
Re: LS Engine Swap
Thanks to both of you, it sounds like I'm at least on the right track. It's nice there is so much information out there (even though it can be a bit much to sort through) and the forums are especially helpful.
narlee is offline
post #5 of 14 (permalink) Old Sep 25th, 16, 05:20 PM
Roger
CarAddict's Avatar
Re: LS Engine Swap
I just put the entire system in my 69, right down to the exhaust. It all fit very nice. It has a nice spacing on the firewall which makes it nice for fitting the harness and other hoses
CarAddict is offline
post #6 of 14 (permalink) Old Sep 25th, 16, 07:43 PM
Garth
Re: LS Engine Swap
X3 on the Holley stuff. Did it on mine, would do it again.
1969 Camaro SS 350 LeMans Blue
2015 Z/28 - Red
2 x 1967 R/Tís
1977 Power Wagon
69L48Z27 is offline
post #7 of 14 (permalink) Old Sep 25th, 16, 10:22 PM Thread Starter
Gary
Re: LS Engine Swap
Thanks for they information, hope you are there when I have more questions.
narlee is offline
post #8 of 14 (permalink) Old Sep 26th, 16, 05:25 AM
Greg
Re: LS Engine Swap
I have all the Holley stuff sitting in my garage and with any luck I will be setting the LS3/4L70e in soon. From everything I have read and saw first hand the Holley stuff is great albeit pricey.
My 69 Build thread :
1995 Z28 (sold)
1987 Iroc-Z (sold)
2005 350Z (sold)
gphusker is offline
post #9 of 14 (permalink) Old Sep 26th, 16, 07:54 AM
Re: LS Engine Swap
Can't speak on the Holley kit since it came out after my swap. But, will say there is a price you pay for a "kit" already assembled and one call takes care of it all Vs. piecing together a kit (Same thing for a front drum to disc kit BTW )
Peace of mind knowing it all fits and been tested carries a price
post #10 of 14 (permalink) Old Sep 26th, 16, 09:29 AM Thread Starter
Gary
Re: LS Engine Swap
Thanks, I figure there are enough things to go sideways if you can get something you know will work it can save some of the headaches.
narlee is offline
post #11 of 14 (permalink) Old Sep 26th, 16, 05:16 PM
foreverlookin's Avatar
Re: LS Engine Swap
Gary please keep us posted as I am thinking of going in the LS3 direction myself. Hope it goes well!
Thanks Steve
foreverlookin is offline
post #12 of 14 (permalink) Old Sep 26th, 16, 05:38 PM
DT
Donny
DT's Avatar
Re: LS Engine Swap
Yes as mentioned above, Good Luck. I'm setting my convertible up now for an LS swap as well. I too have the Holley stuff. On the garage shelf right now though LOL.
DT is offline
post #13 of 14 (permalink) Old Sep 26th, 16, 06:07 PM Thread Starter
Gary
Re: LS Engine Swap
I'll let you know how things go but bear in mind I'm on the slow side and have another project going at the same time. Seeing as how the response to the Holley/Hooker stuff was positive I'll probably order tomorrow so I'll post when it gets here and let you know how it goes from there. Maybe Donny will get his stuff off the shelf and can let us know how it went. Only a couple of days ......right???
narlee is offline
post #14 of 14 (permalink) Old Sep 26th, 16, 06:31 PM
DT
Donny
DT's Avatar
Talking Re: LS Engine Swap
Prob on the shelf for 6 months now LOL
DT is offline
