Oil pan/crossmember clearance question - Team Camaro Tech
post #1 of 7 (permalink) Old Sep 28th, 16, 10:20 AM Thread Starter
Nick
Hi. About 18 years ago i built and installed a 383 stroker in my 68 camaro. I have an small oil leak from the pan gasket and the pan itself is dented. So i am thinking of changing out both the pan and the gasket. I have a th350 transmission with the original powerglide crossmember in the car. My question is when i change the oil pan will it clear the crossmember or will i have to lift the engine to get the old pan out and new one in? Thanks for your help.
Nicc21 is offline
post #2 of 7 (permalink) Old Sep 28th, 16, 10:32 AM
ds1
Dan
Re: Oil pan/crossmember clearance question
The oil pan cannot be removed unless the engine is lifted up. It will not clear the crossmember.
ds1 is offline
post #3 of 7 (permalink) Old Sep 28th, 16, 11:47 AM Thread Starter
Nick
Thanks. I was afraid of that. I will have to figure out the best way to do that without a hoist.
Nicc21 is offline
post #4 of 7 (permalink) Old Sep 28th, 16, 12:10 PM
Ty
69&76's Avatar
Better hit the gym...
69&76 is offline
post #5 of 7 (permalink) Old Sep 28th, 16, 06:22 PM
I've done it with the small block engine and transmission still in the car. Crank the crankshaft until the TDC mark on the vibration damper at the 5 o'clock position to get the front crank weights out of the way. Disconnect negative battery cable, pull your distributor or at least the cap, drain cooling system and disconnect/remove your radiator hoses. Probably a good idea to remove the exhaust system pipes from the engine as well. Put a 2"x4" across the flat bottom of the oil pan and put a jack in place with enough pressure that the engine starts to relax the suspension as you jack it up. Remove the nuts from your motor mount hinge bolts (the bolts that hold the two halves of the motor mounts together) and then remove the bolts.
At this point the only thing holding the engine and transmission in place is the transmission cross member mount and the jack under the oil pan. Jack the engine up as high as you can, the higher the better and at least until you can slide the 1.5" thick portion of a small 2"x4" stud blocks in between the mount halves. If you can slide an extra piece of plywood in there as well even better. Now you can lower the jack as the engine is supported by the wood blocks between the mount halves. Might be helpful to remove the starter as well, and finally remove the oil pan.
I think that's everything.
NH69Z28RS is offline
post #6 of 7 (permalink) Old Sep 30th, 16, 03:52 PM
Bobby
I took the oil pan off a small block in my 67. I just loosened the exhaust and removed the starter, Jacked the engine up with a bottle jack positioned on the block where the starter was and then removed the engine mount bolts and the oil pan bolts. Rotated the crank until the pan can be removed.
There was a brief moment when I thought I'd be better off pulling the engine but, it really wasn't that bad. I'd do it that way again if I had to.
67 Camaro 350
M20 4spd console,
8.5, 30 spline Eaton posi 373
Cowl Plenum
Custom 180 Headers
black/black
no radio
Luwi67 is offline
post #7 of 7 (permalink) Old Oct 1st, 16, 08:45 AM Thread Starter
Nick
Thanks alot for the tips guys. Both of those methods sound like they will work for me. I think i will tackle that task at the end of the month when i get paid again.
Nicc21 is offline
