Finding A New Set of Headers - Team Camaro Tech
post #1 of 11 (permalink) Old Oct 1st, 16, 01:50 AM Thread Starter
A
So another post about headers
I currently have a set of hookers 2451 headers but I want some ceramic coated headers. The driver side header currently runs on the floor when I hit alarms bump. So I'd like to get a different brand or set to see if it changes anything. Any recommendations?
Are there any shorty headers that fit my 327 camaro with power steering, AC and clutch linkages?
1967 RS In Progress
327 with a 4 speed
XedLos is offline
post #2 of 11 (permalink) Old Oct 1st, 16, 05:18 AM
Re: Finding A New Set of Headers
Dyna Tech make great looking and great fitting long tube headers, mine fit with no problems anywhere. they tuck up nice to the floor and clear the power steering. Sanderson also make good shortie headers
67 R/S Blue 406 518HP and 504TQ Dart block,Callies crank,Mahle pistons,Ultradyne cam 230/238 duration @.050 530 lift at 113 lsa, Afr 195 heads,Holley 4150HP carb and RPM Air gap. TKO600 with 373 gears
mike's blue67 is offline
post #3 of 11 (permalink) Old Oct 1st, 16, 07:23 AM
Another vote for Dyna Tech for all the reasons Mike listed.
NH69Z28RS is offline
post #4 of 11 (permalink) Old Oct 1st, 16, 12:54 PM
Cory
i have a set of Flowmasters, SS and ceramic coating. I have a BBC and everything clears. I like what I got !
https://www.summitracing.com/parts/f...t/model/camaro
1968 Firebird - Gen IV 496 Stroker - TH400 - Caltrax rear suspension system w/slider boxes - Corporate Posi Rear with New Axel's - Long Tube Headers, Pypes Race Pro Dual Exhaust and Lotsa other Goodies =)
Arkangel77 is offline
post #5 of 11 (permalink) Old Oct 1st, 16, 03:33 PM
Doug
Another header that fits good is Doug's Headers.
camarodriver67 is offline
post #6 of 11 (permalink) Old Oct 1st, 16, 11:11 PM
Darin
ilikeike's Avatar
I don't know about any shorty headers,but I know that Dougs and dynatech fit about aswell as you can get for an off the shelf long tube.
My dynatechs couldn't get ant tighter to the floor or crossmember without causing interference.
I don't think any header with a 3 bolt non-rotatable header to collector flange should be considered now days,there are far better options.
I know I've replied to 2 or 3 of these posts in the last couple of months. some very recent results with good information should show up if you search headers.
1968 Butternut Coupe,
421" Dart SHP block
TKO 600 RR
Dutchman 9" w/3.70 US Gear Lightning r&p
Global West arms
Budnik wheels
ilikeike is online now
post #7 of 11 (permalink) Old Oct 2nd, 16, 01:25 PM
Jason
blue89bird's Avatar
I've got a set of I think summit headers that checks all of those boxes. Slightly used but I'd sell them rather cheap if you're interested.
Jason
2009 CTS-V - 1968 Camaro 327/M20 Sequoia Green
blue89bird is offline
post #8 of 11 (permalink) Old Oct 2nd, 16, 07:20 PM
Smile Re: Finding A New Set of Headers
Finding a header that clears the factory a/c suitcase is a challenge. Doug Thorley Tri-Y headers is one of the few that do. If your headers hit the floor when you hit a speed bump, I would check the condition of your body mount bushings and engine mounts.
https://www.summitracing.com/parts/d...make/chevrolet
TJS69 is offline
post #9 of 11 (permalink) Old Oct 2nd, 16, 07:37 PM
jared
X2 on Dynatech headers. Just put a set on my 67 with a 383. Fit great and still had tons of room. Also the new ball and socket flange is the only way to go... love them.
67 RS/SS 383/450 h.p TKO 600 3.55 gears
jcfcamaro is offline
post #10 of 11 (permalink) Old Oct 2nd, 16, 07:47 PM
According to Sumitt - Dynatech street stock headers can clear AC also. https://www.summitracing.com/parts/d...make/chevrolet The Dynatech Muscle Max will also work with AC. https://www.summitracing.com/parts/d...nditioning/yes
Some Dynatech headers will not fit AC so choose wisely !
TJS69 is offline
post #11 of 11 (permalink) Old Oct 2nd, 16, 08:02 PM
Vega$69's Avatar
I jus put a set of Hooker mid length headers on a car I'm doing for a friend. The mids were used for max ground clearance.
Easy install and very good clearance all around.
Vega$69 is offline
