starter - Team Camaro Tech
post #1 of 2 (permalink) Old Oct 2nd, 03, 03:54 PM Thread Starter
guys would a 68 302 starter be considered a high torque starter.the 327 and 302 have different part numbers.i would prefer a high torque.are they the same physically.this set up is for a 78 engine and a 403 bellhousing in my 68 i think the block is double tapped for straight or diagonal.and were the bellhousings different on 350s 302s and 327s.thanks jeff
68 redcam is offline
post #2 of 2 (permalink) Old Oct 3rd, 03, 03:54 AM
Jeff,
The bellhousings and statrer etc were the same for the 327 and the 302.
The 350 used a bigger bellhousing "621" and a bigger flywheel @ 14" and a bigger clutch @ 11", a different starter, and a different starter brace.
The only difference between High Torque and regular is the length of the starter body/armature assy. You can interchange the long one for the short one and keep the nose cone etc. It only takes a minute to change once you have done it a few times.
-Mark.
stingr69 is offline
