Motor mounts - Team Camaro Tech
 3Likes
post #1 of 22 (permalink) Old Oct 9th, 16, 03:29 PM Thread Starter
Mauimax3's Avatar
Motor mounts
Can anyone tell me if the "tall style" motor mounts were the only style used in 1st gens? I'm putting a 454 in my 68 and I know that 396 and 454's are identical on the outside and can only seem to find the tall style mounts for the 396? Just hate buying things twice. Thanks for your help.
Army Vet
Car Enthusiast
Mauimax3 is offline
post #2 of 22 (permalink) Old Oct 9th, 16, 03:52 PM
Greg
Re: Motor mounts
There were tall and short. Also the BBC mounts were offset forward to allow additional firewall clearance. We have a place here local called Camaro Concepts that can hook you up.
Mauimax3 likes this.
Lilrat468 is offline
post #3 of 22 (permalink) Old Oct 9th, 16, 04:01 PM
Re: Motor mounts
Camaro - Engine
TC # 349
zdld17 is offline
post #4 of 22 (permalink) Old Oct 9th, 16, 07:55 PM
Smile Re: Motor mounts
For Big Block engines the 67/68 engine mounts are the short and wide. These engine mounts use taller frame stands then the 69' tall and narrow engine mounts. The combined height of frame stands and engine mounts is almost identical. You can not mix and match the frame stands and the engine mounts.
TJS69 is offline
post #5 of 22 (permalink) Old Oct 10th, 16, 08:22 AM
Bill
Re: Motor mounts
My motor mounts fit great, problem is no clearance for header at p/s gearbox.....I hav a set of hookers 2457hkr & tried hedman 63618 neither will clear the p/s gearbox with a 502, plus the hookers won't clear the bottom head bolts. The motor mounts are 2-1/4" to centre of bolt hole and the drivers side stand is 1-1/2" to center of bolt hole and passenger side is 1-3/4" to centre of bolt hole. Are there any out there that will fit
sask68camaro is offline
post #6 of 22 (permalink) Old Oct 10th, 16, 10:52 AM
Do you have the correct big block frame stands and transmission crossmember ? If you have an aftermarket crossmember, make sure that it has the correct offsets. The transmission mount needs to be 1/2" to the passenger side and 3/4" forward of the small blocks location. If you do not have this your engine and transmission will sit crooked and your headers will not fit properly.
TJS69 is offline
post #7 of 22 (permalink) Old Oct 10th, 16, 11:06 AM
If you look at the chart above, your measurements match those for a 350 small block. See if there are any part numbers on the stands and see what they are n this chart.
TJS69 is offline
post #8 of 22 (permalink) Old Oct 11th, 16, 12:20 AM
Originally Posted by sask68camaro;
3746730 The motor mounts are 2-1/4" to centre of bolt hole and the drivers side stand is 1-1/2" to center of bolt hole and passenger side is 1-3/4" to centre of bolt hole. Are there any out there that will fit
I just reread the above posts and you do have the correct big block frame stands. Your 2 1/4" dimension threw me off. That number should only be 1 3/4" for the Short and wide 67-68 engine mounts.
TJS69 is offline
post #9 of 22 (permalink) Old Oct 11th, 16, 07:31 AM
Bill
Re: Motor mounts
Thanks Tom, I had the engine down on the mounts before I tried to install the header and it fit the mounts perfectly, so I thought the mounts were correct. I bought the car as a roller & the seller said it was a big block in it before.
post #10 of 22 (permalink) Old Oct 12th, 16, 06:24 AM
mike
Re: Motor mounts
My motor mounts seem to be wider then the stands, if I had to guess maybe 3/8's of an inch. Does this mean the stands are wrong or the engine mounts are wrong? Is that normal? The motor does sit to one side, so it makes me think the stands are right(maybe they are too narrow?). Sorry not to steel the thread but now that I read this thread it made me think about it.
bigblockragtop is offline
post #11 of 22 (permalink) Old Oct 12th, 16, 07:30 PM Thread Starter
Mauimax3's Avatar
Re: Motor mounts
Thank you!! that helped...got the short and wide and bought a set of the OEM frame mounts.. mocking up the block, trans, and hedders onto the subframe before I roll it under the body..
ID:	163154   Click image for larger version
Army Vet
Car Enthusiast
Mauimax3 is offline
post #12 of 22 (permalink) Old Oct 12th, 16, 09:50 PM
WOW ! That underside sure is pretty ! Now, don't forget the BBC transmission crossmember ! Are those hotchkis sub-frame connectors ?
TJS69 is offline
post #13 of 22 (permalink) Old Oct 20th, 16, 05:38 AM
Bill
Re: Motor mounts
Hello again, if I went with the shorter mounts the hooker 2457 would be even closer to the steering box the
post #14 of 22 (permalink) Old Oct 20th, 16, 12:43 PM
There are not any shorter mounts !
Tall and narrow engine mounts + '69 frame stands = 3 7/8 combined height.
Short and wide engine mounts + '67/'68 frame stands = 3 15/16 combined height
You cannot mix the engine and frame mounts !
TJS69 is offline
post #15 of 22 (permalink) Old Oct 26th, 16, 12:34 PM Thread Starter
Mauimax3's Avatar
Re: Motor mounts
Thanks, the connectors are Global West. Is there really a difference in trans crossmembers?? ...and is there a way to distinguish the difference if there is?? I just put the one that came with the car in..
Army Vet
Car Enthusiast
Mauimax3 is offline
