.030 DZ302 pistons, what are they worth? - Team Camaro Tech
post #1 of 10 (permalink) Old Oct 14th, 16, 08:06 AM Thread Starter
Jeremy
Hi All,
Rebuilt this summer and had to go .040 on my DZ so I have a complete set of .030 dome pistons to sell but no idea what a used set is worth? Can someone help?
ID:	163210   Click image for larger version
ID:	163218   Click image for larger version
ID:	163234   Click image for larger version
jeremywrags is offline
post #2 of 10 (permalink) Old Oct 14th, 16, 08:25 AM
Gary
69Z28-RS's Avatar
Re: .030 DZ302 pistons, what are they worth?
What is the compression of those pistons given stock block and heads?? The dome looks a bit big for the stock compression....?
Gary
69Z28-RS
Corvettes (5), Nomads (2), El Camino, etc
69Z28-RS is offline
post #3 of 10 (permalink) Old Oct 14th, 16, 09:49 AM Thread Starter
Jeremy
That's a great question, is there any way for me to tell? I'll be honest, all I know about them is that they are .030 and were in the car when I bought it. The car ran fine on 91 but much much better with 100LL or VP110 but I am not sure that tells you much.
Is there some measurement that I could take? As for the engine before I rebuilt, original Intake, original heads, original everything as far as I can tell.
Original 1969 Z28 Lemans Blue
post #4 of 10 (permalink) Old Oct 14th, 16, 11:15 AM
They look like older Trw, Speedpro, 11 or 12 :1 but if you can clean up the top of the piston , you may find numbers.
TC # 349
zdld17 is offline
post #5 of 10 (permalink) Old Oct 14th, 16, 11:32 AM
Camarodude67
Cant imagine why anyone would use old pistons if they were going to build a Original 302 DZ or any other Chevy small block, why take the chance?
camarodude67 is offline
post #6 of 10 (permalink) Old Oct 14th, 16, 12:27 PM
They probably did like I did many years ago with my original 302 block. Bored it .030 and put 12:1 pistons in and raced it.
But that was very long ago when no one knew the DZ stuff was supposed to be the king of motors.
Scrap off some of that black off the pistons and see if there is a part number.
I ran H/MP with my 55 that had my original dz block .
TC # 349
zdld17 is offline
post #7 of 10 (permalink) Old Oct 14th, 16, 12:54 PM
Jermey , or Jeff. The number hangs in the back of my head, If those are 302 (compression height) pistons, LF 2210 is burned in my head. And other that some that wants to build a non numbers motor, those would work. Just need a crank and a few other pieces. .
TC # 349
zdld17 is offline
post #8 of 10 (permalink) Old Oct 15th, 16, 07:39 AM
Probably a hundred at best. Used to use parts like this to build claimer motors. Get a 350 (or small journal 327) block and a 283 crank with spacer bearings and 12:1 302 pistons. Not used too much anymore. Too many other options.
70lt1z28 is offline
post #9 of 10 (permalink) Old Feb 7th, 18, 09:35 AM
Probationer
Bruce
do you still have them?
Chidz is offline
post #10 of 10 (permalink) Old Feb 9th, 18, 03:39 PM
Randy
If they are TRW - they should have L2210AF .030 stamped on the top.. not on top of the dome but the flat area.. and if so they can be cut down at least .100 to lower the compression somewhat if needed.
Documented Canadian 1968 Z/28
realzed is offline
