Use the rubber gasket or not? - Team Camaro Tech
 1Likes
post #1 of 16 (permalink) Old Dec 10th, 16, 03:28 PM Thread Starter
Dean
islanddean's Avatar
I'm getting ready to install the intake manifold on my 327 engine. The gasket kit that I purchased came with two rubber end gaskets and I'd like to know your opinion as to weather I should use these rubber gaskets or not.
If I use a large enough bead of RTV on the ends would that make a better seal? ALso...should I place RTV the entire length of the side gaskets or would a bead around the water jacket holes be adequate.
Thanks in advance for any advice.
1967 Camaro Convertible with a 327, TH350transmission, Edelbrock 1406 600cfm carb, Edelbrock 1721 fuel pump & 2701 intake.
"The true measure of a man is not where he stands in time of comfort and convenience but where he stands in time of challenge and controversy."
MLK
islanddean is offline
post #2 of 16 (permalink) Old Dec 10th, 16, 04:29 PM
Re: Use the rubber gasket or not?
Yes and no.
The manifold should sit about an eighth inch above the China rails (the end of the block that seals the lifter valley) when torqued in place. As such an eighth inch bead will be a better choice because it will resist leaks as well as being blown out better than a gasket and sealant. However too thick of a gob of RTV due to a poor fitting manifold (off shore knock off), or previous machine work such as angle cutting the heads, will open that gap up and result in problems. You don't want that RTV bead to slip and fall inside the engine clogging the oil pick up. Test fit to see your end gap first.
Big Dave
Larger Dave is online now
post #3 of 16 (permalink) Old Dec 11th, 16, 06:17 AM
I always just did a RTV bead and like Dave said, test fit first so you can see what you need.
Also, be sure to give it time to cure before start-up
68 Camaro~LSx ~all motor
post #4 of 16 (permalink) Old Dec 11th, 16, 08:05 AM
Chris
You might find the information in the article at the link below useful. This article is posted on CRG's site along with a ton of great information. Check out the link on that site to JohnZ's Tech Articles for other good information. Hope this helps.
http://camaros.org/pdf/intake_swap.pdf
'69 Z/28, Lemans Blue/White Stripes, DZ302, Tremec Magnum, 4.10, Procar Elite Seats,
Custom Upholstery, Dynatech headers, 17" VWW V45's, 235/45, 275/40, C5 Front Brakes
ctcz28 is offline
post #5 of 16 (permalink) Old Dec 16th, 16, 08:59 AM
I use Permatex "the right stuff" .. so far im really liking that stuff..makes great seals.
Long Gone: 1984 Z28, 1989 RS
Current : 1967 Coupe w/350, 2010 2SS
My Photobucket >>
dragon0123 is offline
post #6 of 16 (permalink) Old Dec 16th, 16, 09:18 AM
First thing I do is throw out the cork or rubber end gaskets. Then I use sealer all the way across both ends.
'69 SS396 X66 L34 08D M21 BS
460ci Gen VI 9.75:1 AED 950 carb
Semper Fi!
HawkX66 is offline
post #7 of 16 (permalink) Old Dec 16th, 16, 09:27 AM
X2 , but remember , if you use rtv , you need to apply a thick enough bead (set intake on block to determine) and you need to allow the rtv to cure, before setting intake on. Read the directions on the tube, you will make a neater seal.
And use rtv same color as engine paint. Looks neater also.
TC # 349
zdld17 is offline
post #8 of 16 (permalink) Old Dec 16th, 16, 09:47 AM
Rick
X2 Works great. Easy to razor blade off if you ever need to.
69 COPO clone, 461" BBC 11.25:1 Compression
840 Rec Heads (2.25/1.88) AED 850 HO carb
Orig Exhaust Manifolds
Straub (Clay Smith) cam, 288/300 .600/.569 109.
TH400, 3500 stall, 4.11 12 bolt posi
rp930 is offline
post #9 of 16 (permalink) Old Dec 16th, 16, 10:41 AM
Darin
ilikeike's Avatar
RTV Ultra Black, and about 1/4" bead for me, I let it set up for about 10 min,then drop the manifold on.
"Permatex® Ultra Black® Gasket Maker
Maximum Oil Resistance RTV Silicone
22072
For Heavy Duty Oil Applications
Ideal for Maximum Gap Coverage
OEM Specified
Sensor Safe"
1968 Butternut Coupe,
421" Dart SHP block
TKO 600 RR
Dutchman 9" w/3.70 US Gear Lightning r&p
Global West arms
Budnik wheels
ilikeike is online now
post #10 of 16 (permalink) Old Dec 16th, 16, 12:46 PM
Chick
68camaroz28's Avatar
Lot's of good info and agree especially reading John Hinkley's report but Big Dave brought out a point that has compounded the issue of sealing, that being a poor match up due to the heads being milled, a deck job or whatever so check that out. I Know its bit me many moons ago.
Chick
68, 69, & 2015 Z/28's
69 Nova's L34 Father/Son & L78 Surv purch-new
67, 68, & 2015 Z06 Corvettes
Our 68Z Restoration
68camaroz28 is offline
post #11 of 16 (permalink) Old Dec 16th, 16, 01:57 PM
X3 I used to swear by ultra-black before I found this...
Ultra-clean is important - final clean with lacquer thinner. Roughing up the china walls and corresponding surfaces on intake with 40 grit roloc helps
https://www.camaros.net/forums/18-eng...-straight.html
ctcz28 likes this.
BPOS is offline
post #12 of 16 (permalink) Old Dec 16th, 16, 09:15 PM
mike
Same thing for big blocks?
bigblockragtop is offline
post #13 of 16 (permalink) Old Dec 17th, 16, 11:16 AM
Rick
Yes
rp930 is offline
post #14 of 16 (permalink) Old Dec 17th, 16, 05:31 PM
Vince
Do not use RTV, it tends to squeeze out the gasket when tightened down. Something like Permatex or 3M weathestrip adhesive.
Vince
68 Camaro standard original 327 4 speed Laguna Blue black standard interior.
caldrovp is offline
post #15 of 16 (permalink) Old Dec 17th, 16, 07:54 PM
Morgan
I have used the this:
Ultra or the right stuff, the right stuff is tackier and seems to stick better. I use my finger and put done a real thin ski coat on both the wall and the intake and then run the bead on the wall and hand tighten down the intake and wait an hour and then torque to spec, never had a leak yet. I use the same technique for thermostat housings except I use the grey stuff permatex makes for coolant, it is grey and is the chest for the alluminum intakes
69 Copo 9560 ZL-1 automatic [email protected], 1.95 on f70-14 polyglas F.AS.T. Race June 2016
69 Copo 9560 ZL-1 4spd [email protected] 1.93 60ft on F70/14
PSMCDR 2014
71LS6 vette [email protected] PSMCDR 2012 SOLD
1971ls6 is offline
