firing order - Team Camaro Tech
post #1 of 5 (permalink) Old Dec 11th, 16, 09:23 AM Thread Starter
kevin
firing order
watched ENGINE POWER this morning where they built an engine 580?something . their bump stick had 4 and 7 firing order reversed why?
they also used a belt driven distributor . is there that much advantage doing this?
flat tire is offline
post #2 of 5 (permalink) Old Dec 11th, 16, 11:40 AM
Steve69SS396's Avatar
Re: firing order
The 4/7 swap is supposed to smooth out the power a bit. The cam in my motor has a 4/7 swap. Belt driven distributors are typically used if you have firewall clearance problems. They have to be used with a crank trigger. A crank trigger is more precise than having the pick up in the distributor.
Steve69SS396 is offline
post #3 of 5 (permalink) Old Dec 12th, 16, 12:07 AM
Re: firing order
Belt drive distributor is more precise than a rear shaft driven distributor, overkill for the street but some wankers do run them
rodent4 is offline
post #4 of 5 (permalink) Old Dec 12th, 16, 06:18 AM
Re: firing order
Because all the cool kids are doing it.
A waste on the street, I agree.
68 Camaro~LSx ~all motor
post #5 of 5 (permalink) Old Dec 12th, 16, 07:56 PM
Bobby
Re: firing order
I read somewhere the 4/7 swap and 4/7-3/2 swap were meant to help crankshaft reliability in endurance racing if I recall correctly.
67 Camaro 350
M20 4spd console,
8.5, 30 spline Eaton posi 373
Cowl Plenum
Custom 180 Headers
black/black
no radio
Luwi67 is offline
