ZDDP Levels - A List for Various Oils - Team Camaro Tech
 4Likes
  • 3 Post By ctcz28
  • 1 Post By Sauron67MM
post #1 of 9 (permalink) Old Dec 27th, 16, 11:12 AM Thread Starter
Chris
Recent posts soliciting oil recommendations and related comments about zinc and phosphorous levels in various oils peaked my curiosity so I put together the attached table showing the Zn and P levels for a few popular oils. I've not attempted to provide a comprehensive list and your oil may not be on the list. If you have more interest I'd suggest consulting the MSDS or Product Technical Sheet for any oil you're considering, don't take my word for it. I just wanted to provide a starting point from which to begin your research or if you're using an oil with less ZDDP than you want it may be time to reconsider your choice. A level of ZDDP of about 1200 ppm seems to be the recommended minimum and levels that are too high may create certain negative unintended consequences.
Name:	Oil Zn-P Levels.jpg
Larger Dave, Deangelo66 and 6t9z28 like this.
'69 Z/28, Lemans Blue/White Stripes, DZ302, Tremec Magnum, 4.10, Procar Elite Seats,
Custom Upholstery, Dynatech headers, 17" VWW V45's, 235/45, 275/40, C5 Front Brakes
ctcz28 is offline
post #2 of 9 (permalink) Old Dec 27th, 16, 11:37 AM
Robert
rtchaney's Avatar
Re: ZDDP Levels - A List for Various Oils
That is a useful list. At first, I was worried that a certain user claiming to be an oil guru got a new screen name. Thanks!
. - Rob
1968, 5 speed, Vintage Air Gen IV, American Auto Wire Update Series, Champion 4 Core Rad, BMR front w/ Koni's, BP Roller 383, Posi 8.2", Solid Frame Bushings
rtchaney is offline
post #3 of 9 (permalink) Old Dec 27th, 16, 12:07 PM
George
Gbauer's Avatar
Thanks for putting that together. I've been using the Brad Penn oils since I wiped my cam on Mobile1. Seems like I've made a good choice.
In a pinch I'll substitute VR-1. Also looks good when nothing else better is around.
Sold:
Offy intake
Holley 390 CFM carb
Mild cam
Custom interior
Gbauer is offline
post #4 of 9 (permalink) Old Dec 27th, 16, 03:34 PM
Not on the list: Spectro Motor-Guard, 1800 ppm of zinc and phosphorous. Made in CT.
Call for restoration and custom paint scheduling:
Sauron67MM is online now
post #5 of 9 (permalink) Old Dec 27th, 16, 08:01 PM Thread Starter
Chris
I was surprised to see that there is quite a difference in the ZDDP levels in Mobil 1 10W-30 versus 15W-50. The 15W-50 should be ok for a flat tappet cam. I believe that the heavier weight oils are not subject to the same zinc and phosphorous limits as the lighter weight oils.
ctcz28 is offline
post #6 of 9 (permalink) Old Dec 28th, 16, 08:09 AM
Is that the same company that made/makes "Golden Spectro" that we all swore by for our dirt bikes years ago? They probably still do, but I've been out of it for 15+ years.
'69 SS396 X66 L34 08D M21 BS
460ci Gen VI 9.75:1 AED 950 carb
Semper Fi!
HawkX66 is offline
post #7 of 9 (permalink) Old Dec 28th, 16, 08:30 AM
George
Gbauer's Avatar
I didn't know that until it was too late. Now I just shy away from Mobil1 in the Camaro. In my 14 Mustang GT I've found that dino-oil from Ford (Motorcraft) is actually the best for the engine. Doesn't burn a single drop of that but it seems to burn Mobil1 for some reason. The 2011 Hemi Durango gets Mobil1 still. No burn there.
It kind of goes to show that every engine needs a certain type of oil.
Brad Penn has done me well in the Camaro. After my latest tear down the cam shows no wear and everything inside has zero slop. That said there's still a ton of sludge, though, but I attribute that to 46 years of abuse before I got her. Well that and the 6 just seems to build up sludge regardless of what you do.
Sold:
Offy intake
Holley 390 CFM carb
Mild cam
Custom interior
Gbauer is offline
post #8 of 9 (permalink) Old Dec 28th, 16, 06:24 PM
Yes. Carlquist Competition here sells and uses both Spectro and Penn. Many are aware of Bill's reputation in the industry. Bill just did an L30 for one of my customers.
HawkX66 likes this.
post #9 of 9 (permalink) Old Apr 18th, 17, 08:35 PM
frank
Personally I have always used the heavier weight oil, and I don't live in a climate as hot as Texas. One thing the engine builder has said to me several times........." all the oils look like water after a dyno pull"
wot
frankk is offline
