How to remove seized oil galley plugs? - Team Camaro Tech
 3Likes
post #1 of 20 (permalink) Old Jan 4th, 17, 05:57 AM Thread Starter
Almos
almano's Avatar
Helo,
I have a problem with the three small threaded oil galley plug at the end of the block.
I already broke all my 1/4" drive square sockets.
Tried to heat up, shock, chill. Does not move.
Please help. Thank You.
My restoration project:
1967 Camaro Convertible 327/210HP
almano is offline
post #2 of 20 (permalink) Old Jan 4th, 17, 06:01 AM
Re: How to remove seized oil galley plugs?
If you already tried heat and PB Blaster etc., you might be at the point where you need to carefully drill and collapse the threads.
'69 SS396 X66 L34 08D M21 BS
460ci Gen VI 9.75:1 AED 950 carb
Semper Fi!
HawkX66 is offline
post #3 of 20 (permalink) Old Jan 4th, 17, 06:04 AM Thread Starter
Almos
almano's Avatar
That was afraid of doing.
Any other option?
almano is offline
post #4 of 20 (permalink) Old Jan 4th, 17, 06:36 AM
Agree with Hawk, once you have started this, you have to finish and run a tap to clean out hole as well as the little passages drilled at an angle. I had one like you said, square hole, I drilled it out and collasped the threads. The drilled out hole may be large enough to set an easy-out. Don't break that as its harder than anything you are working with. Don't go back with square plugs, I always good allen head with a teflon sealer. Patience.
TC # 349
zdld17 is offline
post #5 of 20 (permalink) Old Jan 4th, 17, 06:48 AM
DT
Donny
DT's Avatar
Did you use acetylene to heat them up ?? Have to be careful though.
DT is offline
post #6 of 20 (permalink) Old Jan 4th, 17, 06:57 AM Thread Starter
Almos
almano's Avatar
I used MAPP gas i it around 3500 F flame temerature
Don't have Acetylen around.
almano is offline
post #7 of 20 (permalink) Old Jan 4th, 17, 06:58 AM
Pencil point blue flame?
TC # 349
zdld17 is offline
post #8 of 20 (permalink) Old Jan 4th, 17, 07:00 AM
DT
Donny
DT's Avatar
There is your answer. Not hot enough.
DT is offline
post #9 of 20 (permalink) Old Jan 4th, 17, 08:12 AM Thread Starter
Almos
almano's Avatar
I afraid to heat more around the cam bearing journal.
almano is offline
post #10 of 20 (permalink) Old Jan 4th, 17, 08:17 AM
Why? Bearing is out, cam plug is out, ?? Drill it out until you can get a square easy out into hole, threads will collaspe,
DT likes this.
TC # 349
zdld17 is offline
post #11 of 20 (permalink) Old Jan 4th, 17, 08:25 AM
Never had to drill one out in 45 yrs+. I always use a acetaline torch and only heat the inside of the plug, till it starts to smoke real good, then quickly whack it with a punch in center and use a good quality 1/4' adapter on a 3/8 ratchet extension, sometimes you have to do it twice. you can also use a square easy out installed backward into plug after heating and a big crescent wrench.
2002 Jerry Bickle Cavalier, 446" Small Block, Brodix Canted Valve, lenco 5 speed, 7.54 @ 180. mph,1.06 60', 2235 lbs for 2014. GM Canada Docs, Highly Optioned 69 RSZ28 , Hugger Orange, White Stripes, 42,000 mile survivor, owned since 1973.
rszmjt is offline
post #12 of 20 (permalink) Old Jan 4th, 17, 08:37 AM
Vega$69's Avatar
Galley plugs are soft a drill very easy. I'd would center punch and drill out. Then a high quality EZ out followed with a thread chaser.
Vega$69 is offline
post #13 of 20 (permalink) Old Jan 4th, 17, 11:32 AM
Jon
Years ago, when I was working at a machine shop, I fabricated and then hardened a tapered tool out of a small block head bolt to fit the square holes in those plugs. I used to heat the plugs until they were smoking hot with an acetylene torch then hammer my special head bolt tool into the hole and zip the plug out with an air impact.
Commercial ez-outs break so easily that I'd never use one unless I had remove a broken bolt from a wooden 2x4.
Jon N
dyno jonn is online now
post #14 of 20 (permalink) Old Jan 4th, 17, 11:55 AM
If it were me, I'd place a nut over the top of the plug and load it up with mig wire, let it cool of a bit and undo with the appropriate size socket.
Done it many times
HawkX66 likes this.
rodent4 is offline
post #15 of 20 (permalink) Old Jan 4th, 17, 01:18 PM Thread Starter
Almos
almano's Avatar
I just did it!
I ground a 1/2" drive 10mm allen socket to a 1/4" square. warmed up with the MAPP and hit with 1/2" airgun. It came out.
Thanks guys to helping me out with ideas!
Should I remove the two big *** 3/4" square socket plug from the other side of the block? Looks like those are for the water jacket.
ID:	169978   Click image for larger version
almano is offline
