69 DZ302 Vacuum Advance B28 - Team Camaro Tech
post #1 of 14 (permalink) Old Jan 13th, 17, 12:41 PM Thread Starter
Probationer
Alvin
Newbie Here with a 69 RS/Z28 DZ302 & 68 RS Pro Touring LT-1 . I am trying to find a vacuum advance control pod stamped B28, I have read several threads on this from years past but nothing newer than 2013, anyhow my question is did they change the stamp on the canister from B28 to B1 ? A previous thread referenced various part numbers.
NAPA/Echlin VC-1810 which has been discontinued
GM 88924985
AC Delco D1312C
Autozone DV-1810
Borg Warner V329 Which Oreilly's doesn't show as a valid part number, they have a V280 Stamped B1 that cross references with the Autozone DV-1810
I found one at Rock Auto, Airtex 4V1053 which I ordered today but am not certain it will be stamped B28 or B-1. Any assistance would greatly be appreciated. Thanks
RealZ is offline
post #2 of 14 (permalink) Old Jan 13th, 17, 01:51 PM
Rick
Re: 69 DZ302 Vacuum Advance B28
I believe the DV-1810 I got from Autozone was stamped B28
69 COPO clone, 461" BBC 11.25:1 Compression
840 Rec Heads (2.25/1.88) AED 850 HO carb
Orig Exhaust Manifolds
Straub (Clay Smith) cam, 288/300 .600/.569 109.
TH400, 3500 stall, 4.11 12 bolt posi
rp930 is online now
post #3 of 14 (permalink) Old Jan 13th, 17, 02:51 PM Thread Starter
Probationer
Alvin
Thank you Rick, just ordered one from Autozone it will be here tomorrow, if the one I ordered from Rock Auto is correct i'll have a spare. I don't think the one Oreilly's has V280 stamped B1 is correct the Borg Warner # everyone else referenced is V329.
RealZ is offline
post #4 of 14 (permalink) Old Jan 13th, 17, 10:25 PM
Rick
I just looked up my notes on the car and yes the DV1810 was a B28. Hope it works for you.
rp930 is online now
post #5 of 14 (permalink) Old Jan 15th, 17, 07:50 AM
Had my Sister pick me up one last year since she lives in Naples FL during the winter cause no one in Canada sells them. From Autozone below. It gave me too much advance at idle so I made a limiter plate.
My orig 201 15 from my 70 Z28 only gave me 2* at idle with my roller cam and that's why I needed the B28 can, so my idle and performance would be better.
Below: 3/32" will give you 10* more timing at idle without the black bushing in the rod. Note, the black bush isn't used here cause my orig was worn, so I tried insulation from RG 62A coax cable, but it's too soft and the bush ended up with a wear mark from the rod hitting the limiter plate thus changing the vacuum advance number I was trying to achieve. To achieve your desired vacuum advance, you need to file off small increments of the limiter or else you'll be cutting a new piece of aluminum like I had to.
COPO is offline
post #6 of 14 (permalink) Old Jan 15th, 17, 02:21 PM
Morgan
I place a penny between the arm and the plate and hit it with the welder, reduce by 1/3 if the travel for 10 degrees of advance, remove the penny
69 Copo 9560 ZL-1 automatic [email protected], 1.95 on f70-14 polyglas F.AS.T. Race June 2016
69 Copo 9560 ZL-1 4spd [email protected] 1.93 60ft on F70/14
PSMCDR 2014
71LS6 vette [email protected] PSMCDR 2012 SOLD
1971ls6 is offline
post #7 of 14 (permalink) Old Sep 9th, 18, 04:21 PM
Lynn
Old thread I know. Anyone know where to buy a b28 vac advance cannister. No longer available at Autozone.
RockAuto shows an alternate number as a 4V1053, but the specs are not listed. Need a cannister that will fully engage at 8 to 10 inches of vac.
I know Crane makes an adjustable, but I think it is only adjustable for the total amount of advance, not for how many inches of vac.
Any help appreciated.
Lynn
Lynn
bilodeaulynn is offline
post #8 of 14 (permalink) Old Sep 9th, 18, 04:48 PM
Vega$69's Avatar
I have a new one in the box. Just pay shipping if you want it.
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #9 of 14 (permalink) Old Sep 9th, 18, 08:37 PM
Chris
Check out the article I attached below, it will help you find a B28 equivalent.
You can order the B28 equivalent from Auto Zone:
https://www.autozone.com/searchresul...eywords=vc1810
'69 Z/28, Lemans Blue/White Stripes, DZ302, Tremec Magnum, 4.10, Procar Elite Seats,
Custom Upholstery, Dynatech headers, 17" VWW V45's, 235/45, 275/40, C5 Front Brakes
ctcz28 is offline
post #10 of 14 (permalink) Old Sep 9th, 18, 09:01 PM
Beth
Lynn
Lynn,
I bought a 4V1053 from RockAuto and it does have the B28 stamp !
68 Camaro convertible, 6.0 LQ4 with LS3 heads, Vintage Air, 750 street demon carb, eddy perf rpm, GM hot cam, Hooker headers, 4L80e, 12 bolt, 3.55 gears
NashvilleCat is offline
post #11 of 14 (permalink) Old Sep 10th, 18, 01:57 PM
Lynn
Thanks for the input. John: sent you a pm. thanks
Lynn
post #12 of 14 (permalink) Old Sep 10th, 18, 02:54 PM
Rufas
If you want a complete set of instructions, with pictures, absolutely free, no strings, no ads, just send me an email, ask for them, and I will send them to you. gmvacuumadvancemod[email protected]
Two different types of pin stops are shown, home made, and fitting a Crane 99619-1 adjustable degree stop plate on the advance THE RIGHT WAY, so it works correctly.
The B28 advance is correct for the DZ engine. GM used this advance part number for distributor 1111480, 1116201, which is the B28, and the generic 1808, and they are also used on MSD billit trigger distributors as well.
dave ray is offline
post #13 of 14 (permalink) Old Sep 12th, 18, 12:36 PM
Lynn
Email sent to Dave. Thanks.
And, many thanks to John. Received the vac canister today.
Lynn
post #14 of 14 (permalink) Old Sep 13th, 18, 09:36 AM
Rufas
Package sent, ask questions if you have 'em, please.
I just wanted to clarify that in the instructions, to fit the Crane scroll stop, it is recommended to do a small cut away that is covered by the cap when it is on the distributor. This allows easier, from the outside manipulation of the hold down screw for the plate, and moving the plate easier, to change the degrees used.
I DO NOT recommend adding that cut away for a historically correct, numbers matching distributor. When the scroll plate is mounted to the vacuum advance body as outlined, it will work just fine WITHOUT the body cut, just harder to change the setting.
dave ray is offline
