valve problem? - Team Camaro Tech
post #1 of 6 (permalink) Old Jan 16th, 17, 05:53 PM Thread Starter
Probationer
randy
valve problem?
I have a 1969 numbers matching 302 engine. The drivers side valve cover has grooves on the inside cover on the bottom or valve side of cover. all 8 valves have grooves in cover. the passenger side is fine. any thoughts?
randy69 is offline
post #2 of 6 (permalink) Old Jan 16th, 17, 06:46 PM
ZZ_430's Avatar
Re: valve problem?
You mean the rocker arms are grooving the cover?
Try flipping the driver's side valve cover over.
Don ~ TC Member #15 ~
Don't mess with Texas!
ZZ_430 is offline
post #3 of 6 (permalink) Old Jan 16th, 17, 06:47 PM
Re: valve problem?
Is the oil filler cap on the right or left side with this cover? My first thought is they are upside down.
The long little knotches are supposed to fit around intake manifold runners.
TC # 349
zdld17 is offline
post #4 of 6 (permalink) Old Jan 16th, 17, 07:49 PM Thread Starter
Probationer
randy
Re: valve problem?
Oil cap is on back side of drivers side and pvc valve on front of drivers side. it looks like valve spring is touching as it has ringed grooves on valve cover.
randy69 is offline
post #5 of 6 (permalink) Old Jan 16th, 17, 08:33 PM
Re: valve problem?
Post a photo. I have no clue what your talking about.
COPO is offline
post #6 of 6 (permalink) Old Jan 16th, 17, 08:38 PM
Re: valve problem?
Sounds like the valve spring is bouncing around. Springs should be be in their pocket on the head but from what you are saying the valve spring or retainer is what is cutting the cover. I have seen some bad valve guides and weak springs allow this..
What do you know about this motor? Been yours forever? Any chance someone put longer valves or larger springs in this head? Any chance of the rocker arm hitting the cover?
TC # 349
zdld17 is offline
