Converting from points to electronic - Team Camaro Tech
 18Likes
post #1 of 37 (permalink) Old Jan 22nd, 17, 03:40 PM Thread Starter
Guys,
I have a couple questions. I have a stock 327 2bbl with stock points/condenser ignition. I would like to convert to the electronic points systems; i.e. Pertronix. Questions - is it worth it? Will I get better performance? And if so, which Pertronix Ignitor do I need? The original II, or III?
Thanks all,
Troutslayer
Troutslayer is offline
post #2 of 37 (permalink) Old Jan 22nd, 17, 04:02 PM
Rick
Re: Converting from points to electronic
Put in a Crane XR-i and never look back.
Troutslayer likes this.
69 COPO clone, 461" BBC 11.25:1 Compression
840 Rec Heads (2.25/1.88) AED 850 HO carb
Orig Exhaust Manifolds
Straub (Clay Smith) cam, 288/300 .600/.569 109.
TH400, 3500 stall, 4.11 12 bolt posi
rp930 is offline
post #3 of 37 (permalink) Old Jan 22nd, 17, 04:14 PM Thread Starter
Thanks! Can I ask why Crane?
post #4 of 37 (permalink) Old Jan 22nd, 17, 04:28 PM
Apprentice
Put Pertronix in my small block Vette years ago and no problem. Runs great great!!! I'd recommend to anyone.
floydman and Troutslayer like this.
ttoptom is offline
post #5 of 37 (permalink) Old Jan 22nd, 17, 04:37 PM Thread Starter
Thanks. Which Pertronix? the III?
post #6 of 37 (permalink) Old Jan 22nd, 17, 04:58 PM
Rick
The nice part about Crane is it will operate down to 6V, no relay required. I've had one for years. Works great and has a rev limiter.
rp930 is offline
post #7 of 37 (permalink) Old Jan 22nd, 17, 05:21 PM Thread Starter
Should I buy the upgraded coil as well?
post #8 of 37 (permalink) Old Jan 22nd, 17, 05:29 PM
Greg
I swapped years ago on another car. I used the LS series of Pertronix. LS stands for lobe sensor which basically was a true bolt on and go system. If I recall, the original Pertronix unit recommended pulling the distributor in order to correctly install the system. The LS series of unit doesn't require a distributor pull. It was a bolt on and go system.
I used it on my 68 Firebird, because I was concerned with an HEI distributor having clearance issues with my firewall. My Firebird had a 475HP 428 in it and the Pertronix unit handled everything I threw at it.
Greg
69 Camaro SS
427, TKO600 5 speed
Moser built 9" with 3:89 gears
GMW468 is offline
post #9 of 37 (permalink) Old Jan 22nd, 17, 05:54 PM
69-Pace's Avatar
There are many different conversion systems out there all depends on if you want the original dizzy look, wire config etc.
But in general the upgrade is one of the yes you should just as the upgrade to solid state Voltage Regulators is.
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #10 of 37 (permalink) Old Jan 22nd, 17, 06:00 PM
FWIW, A good set of points are cheap, will last many miles, and aren't hard at all to adjust. I don't think there are any major performance benefits to electronic for a 327 2bbl.
1967 RS 327/275hp
trland is offline
post #11 of 37 (permalink) Old Jan 22nd, 17, 06:34 PM
Bill
I agree with Mike, with a stock 327, your points are fine. If you are going to do an HEI conversion, go with Pertronix. I dont know what the diff is between II and III, but if you do a search on this site, there is plenty of info available.
arocars is offline
post #12 of 37 (permalink) Old Jan 22nd, 17, 08:02 PM
Vega$69's Avatar
6 cylinder, 307, 327, 350, 396, 427 all will benefit from electronic conversion.
The benifit is the same whether it's a base 327 or a high performance motor
Vega$69 is offline
post #13 of 37 (permalink) Old Jan 22nd, 17, 08:41 PM Thread Starter
thanks!! I should also mention that I'm adding an Edlebrock 600 Performer Carb and Performer intake as well. Thanks for all the help.
post #14 of 37 (permalink) Old Jan 22nd, 17, 10:35 PM
That is the benifit is the same whether it's a base 327 or a high performance motor
John, Can you specify what those benefits are? I'm not trying to be difficult and you are way more knowledgeable than me on this stuff, but points don't seem like a major problem that needs solving for the average street car.
1967 RS 327/275hp
trland is offline
post #15 of 37 (permalink) Old Jan 23rd, 17, 05:53 AM
Vega$69's Avatar
Points/Condensor work fine when set up and adjusted correctly. They do need more attention and changed once in a while. Setting gap, dwell and timing is not that hard. Points like spark plugs wear and the gap changes over time. The contacts also get burned from the arcing and will need to be filed and re gapped occasionally
Electronics are for the most part trouble free and will last a long time without attention.
The point I was stating was a high performance engine compared to lower performance makes no difference on the decision to convert.
One does not necessarily provide a "hotter" spark spark over the other depending on the coil used.
Vega$69 is offline
