Chevy 350 Headers with stock exhaust system - Team Camaro Tech
post #1 of 2 (permalink) Old Feb 1st, 17, 09:56 PM Thread Starter
Jared
Question Chevy 350 Headers with stock exhaust system
I am asking if the is a header set out there that will mate to with an oem Z28 exhaust system using existing flanges. I would like to keep my existing exhaust system intact without having to cut and weld. Thanks
raygun1954 is offline
post #2 of 2 (permalink) Old Feb 2nd, 17, 07:23 AM
Re: Chevy 350 Headers with stock exhaust system
I am guessing you mean OEM as in stock exhaust that came with a Z car? Not much difference than a SS with duals, transverse muffler. Mine were 2 1/4" double walled pipe all way out back before the axle.
But if you are looking for a better fit , from the header pipes, after you remove the stock exhaust manifolds. I would suggest going to Thorley
TriY as they have smaller collectors you can slip fit connections .
https://www.summitracing.com/parts/dte-376y1c
TC # 349
zdld17 is offline
