what oil weight to use? - Team Camaro Tech
 1Likes
  • 1 Post By DT
post #1 of 14 (permalink) Old Feb 5th, 17, 06:09 AM Thread Starter
Dean
islanddean's Avatar
I have a stock 327 engine and would like a few recomendations on what oil weight would be best. Also...conventional or full synthetic?
Thanks.
islanddean is offline
post #2 of 14 (permalink) Old Feb 5th, 17, 06:16 AM
Re: what oil weight to use?
The experts will weigh in but I'm using Brad Penn 10-30 (partial synthetic) because of its high zinc (ZDDP) content.
'68 RS
VitaminC is offline
post #3 of 14 (permalink) Old Feb 5th, 17, 06:16 AM
Garth
I use Rotella 15w40 in all these types of engines. Just enough zinc to make sure nothing bad happens.
If you run it in the winter with really cold starts you may want a lighter weight.
1969 Camaro SS 350 LeMans Blue
2015 Z/28 - Red
2 x 1967 R/Tís
1977 Power Wagon
69L48Z27 is offline
post #4 of 14 (permalink) Old Feb 5th, 17, 06:42 AM
DT
Donny
DT's Avatar
10W30 Valvoline VR1. It has everything we need for our cars.
rp930 likes this.
DT is offline
post #5 of 14 (permalink) Old Feb 5th, 17, 06:47 AM
Vega$69's Avatar
X2 on VR1
I'm running Lucas Hit Rod Oil in my Z28 with solid lifters.
Vega$69 is offline
post #6 of 14 (permalink) Old Feb 5th, 17, 06:55 AM
Yup, 10W30 Valvoline VR1 here too.
69 Hugger Orange 396 M20 3:31
BRICO69 is offline
post #7 of 14 (permalink) Old Feb 5th, 17, 07:18 AM
Jeff
Grifter's Avatar
Joe Gibbs HR5 10w-40
Grifter is offline
post #8 of 14 (permalink) Old Feb 5th, 17, 07:38 AM
Chris
Assuming you have flat tappets in your stock 327, I'd pay some attention to the ZDDP levels in whatever oil you choose. The link below will get you started with a partial list and a lot of good feedback in the thread. Search the site for info on oils, the members have provided a lot of good recommendations. I'd go with a 10w30 or 10w40 with ZDDP of at least around 1200. This level of ZDDP will rule out many if not most of the garden variety discount store oils.
https://www.camaros.net/forums/18-eng...ious-oils.html
'69 Z/28, Lemans Blue/White Stripes, DZ302, Tremec Magnum, 4.10, Procar Elite Seats,
Custom Upholstery, Dynatech headers, 17" VWW V45's, 235/45, 275/40, C5 Front Brakes
ctcz28 is offline
post #9 of 14 (permalink) Old Feb 5th, 17, 07:40 AM
click's Avatar
Amsoil has an oil for the older flat tappet engines with plenty of ZDDP in it, its called Z-Rod Id recommend that.
click is offline
post #10 of 14 (permalink) Old Feb 5th, 17, 09:13 AM
Your glove box manual will tell you the oil weights to use vs the outside temp.
COPO is offline
post #11 of 14 (permalink) Old Feb 5th, 17, 01:44 PM
Bill
10 W 30 will be fine.
arocars is offline
post #12 of 14 (permalink) Old Feb 5th, 17, 01:54 PM
Daryl
1968RallySport's Avatar
10w30. Pick the brand of your choice.
1968 Rally Sport
302ci
Muncie M22
Moser 12-bolt 4:10 posi
1968RallySport is offline
post #13 of 14 (permalink) Old Feb 12th, 17, 01:34 PM
Mike Petrovich
X2 on Amsoil Z-Rod 10w-30.
1968 327 sport coupe. Son of original owner.
mike p is offline
post #14 of 14 (permalink) Old Feb 12th, 17, 07:11 PM
Bruce
Thanks.
As you can see by the replies, you're asking the wrong question. There are other factors that have to be taken into account if you have a flat tappet camshaft. The EPA made the companies take most of the zinc and phosphorus out of the oil's as they reduce the life of catalytic converter's. without these additives your camshaft wife may be greatly reduced.
I personally use mobile one European blend 0W-40 or Mobile One 15W-50. There are additives you can buy also that contain the things you need.
Coach62 is offline
