LS3 480 / Tremec Magnum Swap pic - Team Camaro Tech
 7Likes
  • 5 Post By ttwo
  • 2 Post By ttwo
post #1 of 13 (permalink) Old Feb 17th, 17, 02:47 PM Thread Starter
TJ
Talking LS3 480 / Tremec Magnum Swap pic
So I did finish my engine swap from a ramjet 350 to an LS3 480 / Tremec Magnum 6 speed. Overall with the Holley Ls3 /tremec swap kit: cross member, oil pain, engine mounts etc. I had only a tiny bit of trimming of the hole to the tunnel. I know what everyone has said that I ABSOLUTELY WILL HAVE TO CUT UP THE TUNNEL to get the Tremec 6 speed in place, but I really didn't. It fit right in and I used my stock center console and everything. I did go to a Dakota Digital Dash. I have to say it went pretty smoothly. I used the clutch and hydraulic kit from American Powertrain. I did have to have my driveshaft cut and balanced. I also put Wilwood brakes all around and Ride Tech front end. It came with a 2 inch drop spindle and I'll be curious as to how it handles differently.
Overall not a cheap mod but I'm excite to see how it runs in a month or so when it warms up. I have been out briefly breaking the engine in and it is/will be a monster!!
ttwo is offline
post #2 of 13 (permalink) Old Feb 17th, 17, 03:57 PM
Brent
67Rally's Avatar
Re: LS3 480 / Tremec Magnum Swap pic
Very nice upgrade!
67Rally is offline
post #3 of 13 (permalink) Old Feb 17th, 17, 09:22 PM Thread Starter
TJ
Here is a before and an (almost done) after photo. I'll post some build pics soon
ttwo is offline
post #4 of 13 (permalink) Old Feb 17th, 17, 11:47 PM
I've got that engine in my '68 in front of a Viper T56. On a Mustang dyno (known to be stingy), through headers and a full exhaust system it made 440 to the rear wheels.
You're going to like that combo!
Mike - '68 Camaro with lots of stuff done to it.
Mkelcy is offline
post #5 of 13 (permalink) Old Feb 18th, 17, 11:19 AM
Rich
Would you mind telling me what angle your motor/tranny are sitting out with your setup? I would be very interested to see what you have with the Holley setup.
Thanks!
1967 SS350, Under construction.
H20cooled is offline
post #6 of 13 (permalink) Old Feb 19th, 17, 07:46 AM Thread Starter
TJ
Thanks!
I estimated from 1.5-3 degrees
ttwo is offline
post #7 of 13 (permalink) Old Feb 19th, 17, 04:45 PM Thread Starter
TJ
The old engine taken out and gave to a friend!
Tangled mess of wires, some are now rerouted
Here are the mounts for the new engine in place
New wiring harness with some wires tucked away now
There She is: March Performance accessory system
right before engine placement
right after she was shoehorned in
ended up taking the quarter panel off for access and placement of the computer
ttwo is offline
post #8 of 13 (permalink) Old Feb 19th, 17, 05:01 PM Thread Starter
TJ
Bottom view with the tranny installed
Hole in the same place as prior, just sealed it up
Wilwood brakes
Dakota Digital dash and console
custom fan mount
tried the flexible stainless hose at first but looked like a vacuum hose :{
I'm now putting together a custom logo on some Eddie Motorsports coil covers.
I made the radiator hose from exhaust tubing and 90 degree hose
H20cooled and Sheck44 like this.
ttwo is offline
post #9 of 13 (permalink) Old Feb 21st, 17, 12:36 PM Thread Starter
TJ
I had two brake issues with wilwood brakes. initially I had a very soft petal that went to the floor. The brakes were power bled but ended up as a new system it still had air so I rebled them and then it was very nice and firm. Then the issue was that they didn't want to let go. there was always a little drag on the brakes and they got hot after only a few blocks. Ended up that the rod coming out of the booster was too long even when it was screwed all the way in, so we had to take the little metal piston out of the master cylinder and drill it out about a quarter inch to give a little free wiggle room so that the brakes would let go and not be engaged all the time. Now they work fine. I still don't have much stopping power to the rear even with the master adjust all the way to the rear . I hope it improves as it self adjusts? Not sure how that will work
ttwo is offline
post #10 of 13 (permalink) Old Feb 21st, 17, 04:18 PM
DT
Donny
DT's Avatar
Very nice!!!
DT is offline
post #11 of 13 (permalink) Old Apr 9th, 17, 10:07 PM
Thumbs up Re: LS3 480 / Tremec Magnum Swap pic
Beautiful!
'67 RS, convertible, factory A/C, 327/275 (M30), powerglide, parchment interior
tri 6's fanatic is offline
post #12 of 13 (permalink) Old Apr 9th, 17, 10:14 PM
Garrett
Awesome!
Sent from my iPhone using Tapatalk
68GK327 is offline
post #13 of 13 (permalink) Old Apr 10th, 17, 04:26 PM Thread Starter
TJ
thanks so much! It was a huge project and so far I just love the difference! The transmission is so smooth and the engine is just a beast!
ttwo is offline
Tags
ls3 480 tremec
