Please Read my Plugs - Team Camaro Tech
post #1 of 6 (permalink) Old Feb 19th, 17, 06:01 AM Thread Starter
Andrew
Andrew69's Avatar
These are replaced after maybe 2,500 miles. What does their appearance say? R45 heat range.
Skunk Works
Some photos:
Member # 159
Andrew69 is online now
post #2 of 6 (permalink) Old Feb 19th, 17, 06:08 AM Thread Starter
Andrew
Andrew69's Avatar
Re: Please Read my Plugs
Attached the photo
Skunk Works
Some photos:
Member # 159
post #3 of 6 (permalink) Old Feb 19th, 17, 06:34 AM
Your on the rich side.
I can't see the curve on the gnd strap to tell where you timing is.
https://www.enginebasics.com/Engine%...k%20Plugs.html
How to read Racing Spark Plugs - Dragstuff
COPO is offline
post #4 of 6 (permalink) Old Feb 19th, 17, 08:02 AM
Chad
cv2065's Avatar
Those look wet and definitely on the rich side. Insulator tip looks OK. Fuel smell? Mine were the same way and had to dial back the timing a bit.
67 Black RS Coupe, 383, M21 & 10 Bolt Posi. Edelbrock E-Tech 170 Heads, 2204 Roller Cam, Air Gap Intake.
cv2065 is offline
post #5 of 6 (permalink) Old Feb 19th, 17, 08:15 AM Thread Starter
Andrew
Andrew69's Avatar
Another photo from the other side and what I replaced these with. Thanks for the input thus far. I really don't notice any fuel smell. I've in the past set the fuel air ratio with the vacuum method and think I have it pretty close. I don't mind doing it again.
Dial back timing will be turn distributor slightly clockwise. Correct?
I watched the long drawn out video. It does present some good information.
Skunk Works
Some photos:
Member # 159
post #6 of 6 (permalink) Old Feb 19th, 17, 08:40 AM
Not enough timing, the color on the strap is in the middle and should be at the curve. Set the timing to 36* total or if you don't have a back dial light 12*-14* initial. Jet down leaner.
COPO is offline
