carb adjustment ? - Team Camaro Tech
post #1 of 4 (permalink) Old Feb 19th, 17, 10:53 AM Thread Starter
kevin
carb adjustment ?
when adjusting a carburetor do you want the highest vacuum reading you can get
I always just used a tach before but it is a PITA with the hei distributor, so I now use a vacuum gauge
flat tire is offline
post #2 of 4 (permalink) Old Feb 19th, 17, 11:11 AM
Re: carb adjustment ?
Yes. A vacuum gauge is more accurate. If you have a Holley, just make sure you have the correct power valve. 1/2 of your highest vacuum reading at idle is the power valve size. Go to the lowest if your on an even # where there is no Holley PV.
I.E. 13"/2=6.5 so get a #65 PV. 8"/2=4 so get a #35 PV.
COPO is offline
post #3 of 4 (permalink) Old Feb 19th, 17, 12:08 PM Thread Starter
kevin
my gauge shows 16.6 " of vacuum, so I should have #82 power valve?
post #4 of 4 (permalink) Old Feb 19th, 17, 09:20 PM
I would go with #85
These PV are avail.
10.5 in
9.5 in
8.5 in
7.5 in
6.5 in
5.5 in
5.0 in
4.5 in
3.5 in
2.5 in
COPO is offline
