Oil to the top side... - Team Camaro Tech
post #1 of 19 (permalink) Old Feb 25th, 17, 10:40 AM Thread Starter
I've searched the archives and gotten an idea about my situation but thought I'd go ahead and ask anyhow. I'm priming an engine built many many years ago and am not getting oil to the rocker arms. I rotate the engine and then prime it, the rotate it more, then prime it more and so on. I'm using a pneumatic drill to prime and it only does 700 rpm but the oil pressure gauge while priming reads over 40 psi (probably higher but by the time I can get to looking inside the car it's already dropped off because I can't prime and watch the gauge at the same time). I'd guess that I prime for 20 seconds, then stop, then 20 more and so on... Does it take continual priming for minutes, or higher rpm's, or both, or maybe old engine lube is clogging holes. Not really sure so I thought I'd ask.
Thanks for any info in advance, Jim
4Speed67CamaroRS is offline
post #2 of 19 (permalink) Old Feb 25th, 17, 11:56 AM
Chad
cv2065's Avatar
Re: Oil to the top side...
I'd probably get a drill with a little more power and see where you are from there. Last time I did it, I think I spun the drill (2500 RPM) for 30-45 seconds before I started seeing oil flowing to the rockers. Then rotate 1/4 turn and continue until you go all the way around and oil is flowing from every rocker. I'd say that every engine is different, but if I wasn't seeing oil flow, I'd figure out where the issue was. I think I was reading 60-70lbs of pressure.
67 Black RS Coupe, 383, M21 & 10 Bolt Posi. Edelbrock E-Tech 170 Heads, 2204 Roller Cam, Air Gap Intake.
cv2065 is offline
post #3 of 19 (permalink) Old Feb 25th, 17, 04:16 PM
"More speed, Scotty" 700 rpm = 350 crankshaft RPM.
Place #1 cyl at TDC with both valves closed and prime with a 1/2 drill motor.
Should see oil in less than one minute if this long.
Then as Chad suggests, rotate 1/4 turn and prime for #8, and so on through firing order.
post #4 of 19 (permalink) Old Feb 25th, 17, 04:44 PM Thread Starter
Okay, I didn't realize it reduces it to half. I'll try a better drill then report back.
Thanks guys, Jim
post #5 of 19 (permalink) Old Feb 25th, 17, 04:57 PM
wrong. crank turns twice cam speed, need to rotate crank to the lifter oil position
john68 is offline
post #6 of 19 (permalink) Old Feb 25th, 17, 05:23 PM
Ken
What are you using to prime it? you either need an aftermarket primer tool or a distributer housing to complete the path from the rear oil feed to the lifter feed. spinning the pump without it just lubes the crank.
ktrim is offline
post #7 of 19 (permalink) Old Feb 25th, 17, 05:33 PM Thread Starter
I have a priming tool. Everything should be good as far as I know but I'm not seeing oil yet. It wouldn't surprise me if I'm doing something wrong though or am not using the correct drill or something. I just bought the pneumatic drill from harbor freight and figured the pneumatic drill would have plenty of room which my battery powered drill driver doesn't to prime the engine. Guess I need to buy a corded power drill.
Thanks guys for the info. Jim
post #8 of 19 (permalink) Old Feb 26th, 17, 04:51 AM
Ken
1/2 electric drill is the way to go, Battery powered generally cant handle it. Run the drill for a few minutes, turn the crank 90* and repeat for at least 2 revolutions. Do you have a standard pump, High pressure, or high volume? The high pressure and High volume can really push a drill to its limits. What weight oil and what is the temp where your at? 20w50 and cold outside can make priming an engine difficult.
ktrim is offline
post #9 of 19 (permalink) Old Feb 26th, 17, 08:52 AM
I used a video camera set on my console to be sure I was getting pressure.
COPO is offline
post #10 of 19 (permalink) Old Feb 26th, 17, 10:38 AM Thread Starter
I'm not sure about the pump being that the engine was built so long ago by someone else. Frankly I don't remember. The oil is 15w-50w BR break-in oil. Temp is mid 60's.
If I need to run the drill two minutes, then that's likely it. I didn't run it for even half that long and only at 700 rpm. Seems I need a better drill.
Thanks, Jim
post #11 of 19 (permalink) Old Feb 26th, 17, 11:05 AM
I ran my drill for more than 2 min before I saw oil. Then I rotated the engine to get oil to the other head. And run the drill at full speed or it won't prime, plus you need a drill that can handle the drag of the pump/oil.
COPO is offline
post #12 of 19 (permalink) Old Feb 26th, 17, 11:20 AM Thread Starter
Any suggestions on a capable drill. I really won't have much use for a corded drill after this so I'm not looking to spend a bunch.
Thanks, Jim
post #13 of 19 (permalink) Old Feb 26th, 17, 01:21 PM
I used my electric impact gun. My cordless and electric drills were no match for the job. You could borrow one.
COPO is offline
post #14 of 19 (permalink) Old Feb 26th, 17, 03:47 PM
Wouldn't a dist dummy shaft and body, connected to the oil pump attached to a drill, spin over long enough to push oil up and out the rockers for priming? That's all I have ever used for priming a motor in or out of the car.
You can hook up a flex hose any old pressure gauge and have it in front of you.
TC # 349
zdld17 is offline
post #15 of 19 (permalink) Old Feb 26th, 17, 06:22 PM
Ken
As long as you have a housing or a primer with the grooved guide it will work, Some guys will only use a shaft with no housing. There is an oil feed in the back of the block that feeds into the groove in the housing, the groove allows the oil to get to the passage on the other side. With out a housing it just pumps back to the pan. I use a 1/2 electric drill and run it for about 2 minutes at a time, turning the crank 90* after each stop. I have tried to run longer but usually the drill will get hot sometimes start smoking. the thicker the oil, the harder it is on the drill. 15w-50 that the OP is using is pretty thick, It will put a lot of strain on the drill.
ktrim is offline
