Looking for individual cam bearngs - Team Camaro Tech
post #1 of 7 (permalink) Old Feb 27th, 17, 10:47 AM Thread Starter
Almos
almano's Avatar
Hello,
I messed up my #1 cam bearing during installation and I need one now. I dont want to buy another set for $80 just for 1 bearing. But i can not find anywhere option to buy individual. Any idea where can i get individual bearings? It was a King HPT bearing CS507HPT.
Thank You.
My restoration project:
1967 Camaro Convertible 327/210HP
almano is offline
post #2 of 7 (permalink) Old Feb 27th, 17, 12:07 PM
Rick
Re: Looking for individual cam bearngs
My guess is you will be buying a set. $47 from NAPA.
69 COPO clone, 461" BBC 11.25:1 Compression
840 Rec Heads (2.25/1.88) AED 850 HO carb
Orig Exhaust Manifolds
Straub (Clay Smith) cam, 288/300 .600/.569 109.
TH400, 3500 stall, 4.11 12 bolt posi
rp930 is offline
post #3 of 7 (permalink) Old Feb 27th, 17, 02:28 PM
The reason behind this is the fact that every cam bearing has a different OD so one can not be substituted (or installed past) another cam bearing.
At least if you find a single bearing it can be installed individually as it is on the outside of the motor where you can get to it.
Big Dave
Larger Dave is offline
post #4 of 7 (permalink) Old Feb 27th, 17, 02:32 PM Thread Starter
Almos
almano's Avatar
Big Dave
It's the #1 so easy to install.
almano is offline
post #5 of 7 (permalink) Old Feb 27th, 17, 02:36 PM
I used to sell GM cam bearings by position , I say , used to, I believe number 1-4 were the same and 5 being different. This was in the 70's. You would have to check with a GM dealer for this , but my guess is , that since most people and builders rely on jobber houses for a set, that you may not find these anymore. Just have to check.
TC # 349
zdld17 is offline
post #6 of 7 (permalink) Old Feb 28th, 17, 06:25 PM
Bill
Almano,
If it was a "standard" cam bearing I would send you one for nothing. But since it is the coated performance variety it is going to be hard to find a broken set. Do you have the ability to call King from where you are ? If so, they would most likely help you out. If you cannot call them I will try to remember to give them a shout in the morning and see what they say.
Bill Koustenis
Owner
Advanced Automotive Machine
Waldorf Md
BillK is offline
post #7 of 7 (permalink) Old Mar 1st, 17, 02:32 AM Thread Starter
Almos
almano's Avatar
Originally Posted by BillK View Post
Almano,
Thank You Bill, You very nice, but I pulled the plug and ordered a news set yesterday. Well I learn the expensive way to be very careful....
almano is offline
