327 with Smog Pump - Team Camaro Tech
post #1 of 6 (permalink) Old Mar 2nd, 17, 05:28 AM Thread Starter
Jonathan
327 with Smog Pump
Good day. I am at the point in my restoration to install the smog pump system. Just trying to make it original to honor my Dad, just the way he bought it in 67. However, I had to replace the intake during the rebuild and the only way I can mount the smog pump, that I can tell, is upside down. This is due to the placement of the heater core hose out of the intake. On the bottom of the smog pump appears to be some sort of breather hole or drain for any particulate that my leak. Anyone know if the "breather" hole inverted will cause problems? Thanks.
Red6a1 is offline
post #2 of 6 (permalink) Old Mar 2nd, 17, 05:30 AM Thread Starter
Jonathan
Re: 327 with Smog Pump
One more question. I can't find details on the three hose fittings on the back. Can someone tell me which hose goes to which inlet/outlet?
Red6a1 is offline
post #3 of 6 (permalink) Old Mar 2nd, 17, 06:56 AM
Any pictures of the "new" intake?
David_396 is offline
post #4 of 6 (permalink) Old Mar 2nd, 17, 07:13 AM
ray
This is a picture of my 68. Hope it is of some help for you.
carcrazy615 is offline
post #5 of 6 (permalink) Old Mar 2nd, 17, 08:12 AM
That hole is the pressure relief valve.
COPO is offline
post #6 of 6 (permalink) Old Mar 3rd, 17, 05:26 AM Thread Starter
Jonathan
Thanks for the information. I upgraded from a 2bbl to 4bbl during the rebuild. Any suggestions on where to find the correct air cleaner for a Holley 4bbl? My old one had two tubes in the bottom. I believe one fed the rear crankcase tube (hole behind distributer) and the second tube went to the smog pump.
Red6a1 is offline
