Vortec Intake Gasket - Team Camaro Tech
post #1 of 9 (permalink) Old Mar 5th, 17, 06:57 AM Thread Starter
Chad
cv2065's Avatar
Anyone ever use the intake gaskets from the Felpro ms98000T set? The rubber on this gasket is supposed to compensate for very minor pitting around the water ports on the intake. Says specifically not to use any RTV on the included directions. I always have used a little RTV around those ports, and wanted to see if anyone had used these gaskets and if they were effective without it.
67 Black RS Coupe, 383, M21 & 10 Bolt Posi. Edelbrock E-Tech 170 Heads, 2204 Roller Cam, Air Gap Intake.
cv2065 is offline
post #2 of 9 (permalink) Old Mar 5th, 17, 07:14 AM
Randy
Re: Vortec Intake Gasket
thats the same gasket I used on my vortec head 327---works very well
1967 camaro, 327, 9.7 CR, comp cam xs274solid, vortec cylinder heads, edelbrock vortec performer rpm, 750 annular carb, HVH 2" spacer, msd pro billet w/6A box, turbo 350 trans, 3500 stall, 4:10 gears, caltracs suspension, m/t drag radials.
rkmjbad67 is offline
post #3 of 9 (permalink) Old Mar 5th, 17, 07:35 AM Thread Starter
Chad
cv2065's Avatar
Thanks Randy. Did you have any minor pitting around the water jackets? Did you use any RTV or just by itself?
cv2065 is offline
post #4 of 9 (permalink) Old Mar 5th, 17, 12:10 PM
Randy
Chad---I dont recall any pitting, but it was a few years back---I only used RTV for the end seals---make sure you get the cylinder head surface nice and clean
post #5 of 9 (permalink) Old Mar 5th, 17, 12:50 PM
Chad, how bad is the pitting , where, on the heads or intake. I had pitting that was bad on the intake and I smeared some JB weld to fill in the spots. I filed it down and used the rtv on ends of 1206 gaskets. I used red rtv for intake valley seals. I let it cure some 5 min before putting on intake. That help form a rubber seal.
TC # 349
zdld17 is offline
post #6 of 9 (permalink) Old Mar 5th, 17, 01:18 PM Thread Starter
Chad
cv2065's Avatar
Don - I guess the aluminum is more 'stained' than pitted around the water ports. Do you know what causes that? Surface is pretty smooth overall. I've used the Ultra Black for the China Walls before and it worked pretty good.
cv2065 is offline
post #7 of 9 (permalink) Old Mar 5th, 17, 05:28 PM
Chad, the intake is where I applied the JB weld . The back cly head ports are basically dead spots as no water really circulates there.
All sbc has this. This corrosion almost ate my stock Z manifold back there. I clean it up and filled it in, sanded JB down and put sealer as you mentioned.
Since I learned this, I have drilled my new intake to circulate water to the T-stat housing adapter. I noticed when I did this, my water temps dropped about 10 as the back cly head spots don't really allow cooling . Not sure if GM ever considered changing the water flow pattern as ever GM sbc I have seen since the first ones in 1954 , were this way. At a museum , I saw the first V8, it was crude but showed the same pattern.
Use the sealer, allow to set a little , then tighten it down. Same for front and rear end seals. Always worked for me. I don't use gaskets there as even the cork will slide our over time or soak up oil.
TC # 349
zdld17 is offline
post #8 of 9 (permalink) Old Mar 5th, 17, 07:00 PM Thread Starter
Chad
cv2065's Avatar
Don - These Felpro ms98000T intake gaskets are backed with a steel insert and have quite a bit of rubber around all of the intake/water ports. Supposedly these are Felpros new design for 'weathered' mating surfaces and the reviews are awesome. Says not to use any RTV as it may cause the gasket to split. I usually use sealant on just about everything, so wanted to see if anyone had used these before.
I've got a new RPM Air Gap manifold I can use. Maybe I'll just use that one as I put a level across this one and can see a small amount of daylight, so not sure its completely straight anyway.
cv2065 is offline
post #9 of 9 (permalink) Old Mar 5th, 17, 07:26 PM
Do as instructions stated. If you have an Airgap, you should have rear tapped holes, to reroute water passage. Its simple. I used the blue hose for water and AN connections.
The silver wrap is heat insulation to keep all fuel lines cool.
ID:	177130   Click image for larger version
ID:	177138   Click image for larger version
TC # 349
zdld17 is offline
