To cam or not to cam? - Team Camaro Tech
 2Likes
post #1 of 21 (permalink) Old Mar 14th, 17, 10:35 PM Thread Starter
Bruce
Ok, base 1967 327/210 HP currently with the top end off. Bought the Edelbrock top end kit 2099 kit with the etec heads, supposed to be one of their top of the line top end kits. The heads are modeled after the Vortec heads with a Vortec intake. Supposed to produce 435 HP out of a 350 with 12' of vacuum at 1,000 rpm.
The heads, intake and carb, along with ceramic coated headers are going on, that's a given. Only question is do I put the cam on now, or save it for another engine?
Just completing phase 1 of my 67 Camaro. Paint, new wheels, tires and some engine mods to cure the 210 hp disease. The engine felt like it was running on 7 cylinders. I *believe* it was the heads, but cannot rule out a worn cam lobe, although I think it is unlikely. Compression test was pretty good, did NOT do a leak down test.
The cam that comes with the top end kit is fairly stout, there is my concern. I believe without the cam, the kit will put out over 300 hp with my 50 year old 327 stock short block. Seeing that the engine put out 275 hp with just a 4bbl carb and double hump heads, I think that is very reasonable. My math says it should put out over 400 hp with the cam.
Cam specs - http://www.jegs.com/photos/300/350/350-2201camcard.jpg
My main concerns - 50 year old power glide (crappy first gear ratio), short block, stock 10 bolt rear end with 2.73 gears. Not a good setup (especially the stock torque converter and 2.73 gears) for a decent cam.
Engine will have 10:1 compression with a steel shim head gasket.
During phase 2 of my upgrades (probably over the winter) I will *likely* but a 383 stroker short block, O.D. (like a 700R4 or similar) trans with a better torque converter, better p-trac rear end with better gears (like 3.73 or so).
Options:
1. Install heads, intake, carb and headers, enjoy the upgrades as-is until I do phase 2.
2. Install above, plus the included cam.
3. Install option 1, with a cheaper, milder cam (not a great option due to the amount of work.) Save the Thumper cam for the final engine.
I'm leaning towards not doing any cam work at this time, but I keep going back and forth. I do have everything to do the cam, but it's a lot more work. I'm a bit concerned that the cam won't work so hot with a stock torque converter, a power glide (crappy first gear ratio) and a 2.73 gear ratio.
thoughts?
Coach62 is offline
post #2 of 21 (permalink) Old Mar 14th, 17, 10:42 PM
Vega$69's Avatar
Re: To cam or not to cam?
Put the cam in and don't look back
Vega$69 is offline
post #3 of 21 (permalink) Old Mar 14th, 17, 10:49 PM
Call Chris over at Straub Technologies. He is a cam guru and can help you. Great guy to talk about your build with.
Sent from my iPhone using Tapatalk Pro
rp930 likes this.
jketron is offline
post #4 of 21 (permalink) Old Mar 14th, 17, 10:51 PM
thoughts?
I'm no expert but way back when I did similar work to my 327/210hp but didn't touch the PG and rear end. I always felt it drove like a turd and wished I had done the trans/rear end too. Just my $.02
VitaminC is offline
post #5 of 21 (permalink) Old Mar 15th, 17, 05:12 AM
Cam spec sheet specifically states for use with high stall converter only. I think this thing will be a dog with your stock converter....
1959 El Camino project
1957 Buick Caballero project
dhutton is offline
post #6 of 21 (permalink) Old Mar 15th, 17, 05:14 AM
Banned
Chet
Every cam manufacturer out there in their catalog will list the torque converter range to go with each cam. Edelbrock is no exception. Look up your cam in their catalog and read the recommendations.
onefiness is offline
post #7 of 21 (permalink) Old Mar 15th, 17, 06:46 AM
Greg
I would throw the cam in and if you feel like any other changes down the road do them.
My 69 Build thread :
1995 Z28 (sold)
1987 Iroc-Z (sold)
2005 350Z (sold)
gphusker is offline
post #8 of 21 (permalink) Old Mar 15th, 17, 07:05 AM
Michael
Besides, the old cam and lifters were end of life decades ago.
I used a Holley SysteMax II kit on my 67 SS 350 and the cam is definitely part of the equation (nice product, good price).
X2, new cam.
Live a little.
mahunt is offline
post #9 of 21 (permalink) Old Mar 15th, 17, 07:22 AM
Darin
ilikeike's Avatar
I wouldn't put it together until I was done with phase 2.
Then put the cam in it.
1968 Butternut Coupe,
421" Dart SHP block
TKO 600 RR
Dutchman 9" w/3.70 US Gear Lightning r&p
Global West arms
Budnik wheels
ilikeike is online now
post #10 of 21 (permalink) Old Mar 15th, 17, 07:56 AM
The cam you selected is better than the cheaper one mainly due to being a hyd roller. First off you don't have to worry about wiping a lobe on start up or in future.
Yes, your rearend ratio is high as with a PG. Unless you want to change it also and keep the PG, you need to work around the cam design. You could be in luck as some PG trans have a lower first gear, but I think that was one out of a 6 cly.
But since you are looking at this expense, go one step further and call Chris.
Consider roller trunion rockers as they free up hp also.
TC # 349
zdld17 is offline
post #11 of 21 (permalink) Old Mar 15th, 17, 08:22 AM
Rick
Get rid of the powerglide first.
VitaminC likes this.
69 COPO clone, 461" BBC 11.25:1 Compression
840 Rec Heads (2.25/1.88) AED 850 HO carb
Orig Exhaust Manifolds
Straub (Clay Smith) cam, 288/300 .600/.569 109.
TH400, 3500 stall, 4.11 12 bolt posi
rp930 is online now
post #12 of 21 (permalink) Old Mar 16th, 17, 06:15 AM Thread Starter
Bruce
I called edelbrock and they said that cam is no good with that setup. They recommended a different roller cam. I also called Comp they said the same thing and recommended a similar cam. I went with the Comp as it was in stock, and I liked it better (higher lift).
Cam should be here tomorrow, with any luck will be in this weekend.
Coach62 is offline
post #13 of 21 (permalink) Old Mar 16th, 17, 07:26 AM Thread Starter
Bruce
Here is the cam I went with.
https://www.summitracing.com/parts/c...422-8/reviews/
Coach62 is offline
post #14 of 21 (permalink) Old Mar 16th, 17, 07:39 AM
George
Gbauer's Avatar
Do the cam and get rid of the 'glide for a build 2004r or 200r4.
My little 250 was putting out even more power than your 210 when I ditched the powerglide for the 2004r. That really woke the car up and made it MUCH more driveable. It was fine before if I didn't want to accelerate or drive above about 55 but other than that... well the trans was holding the car back big time.
Trans and cam first. Then follow that up with a posi and new gearing. That'll make a a huge difference for a street car and keep you from feeling the need to get a whole new engine in it for a while (but when you do the rest will be ready for it!).
edit: I should've read further...
Regardless still pick yourself up a 2004r from a yard and rebuild it with a shift kit and new guts. You'll be in it for $1200 or so by the time it's all done and you'll be able to say you built it yourself.
Sold:
Offy intake
Holley 390 CFM carb
Mild cam
Custom interior
Gbauer is offline
post #15 of 21 (permalink) Old Mar 16th, 17, 08:44 AM
jeff
No power brakes with just 12" of vacuum.
jkuro is offline
