Power Steering Pump - Team Camaro Tech
 1Likes
  • 1 Post By X-77 keith
post #1 of 6 (permalink) Old Aug 17th, 18, 07:25 PM Thread Starter
Dale
Power Steering Pump
Is there any sure-fire ways to tell if your power steering pump is bad. I have a squeaking noise that I believe is coming from the PSP pulley. Seems that it may be just a little bit off of alignment. I also have noise for a little bit after first running that happens when I turn the wheel. Possibly goes away after a little driving or I just don't notice it at least. Fluid level is good.
1. Could this be slippage of too loose of a belt or misalignment?
2. Possibly too tight of a belt causing the misalignment?
3. Bad pump?
4. Something else all-together?
67 Camaro
Wigman87 is offline
post #2 of 6 (permalink) Old Aug 17th, 18, 07:31 PM
keith
X-77 keith's Avatar
I would start with the belt first. Check tension. Is the belt old, or glazed? All could cause a squeel or squeek.
Bigfish45 likes this.
X-77 keith
X-77 keith is offline
post #3 of 6 (permalink) Old Aug 17th, 18, 07:33 PM Thread Starter
Dale
Re: Power Steering Pump
Doesn't appear to be glazed, not sure on the age. Could replace I guess just to be safe. Any recommendations on where to buy a new one from?
67 Camaro
Wigman87 is offline
post #4 of 6 (permalink) Old Aug 17th, 18, 08:08 PM
keith
X-77 keith's Avatar
Almost any auto parts store. I prefer Gates or Daco belts. Do you have any more adjustment left ? Could be that easy. If you are buying a new belt, take your old one with you to match it up with the new one.
X-77 keith
post #5 of 6 (permalink) Old Aug 18th, 18, 08:27 AM
Keep in mind belts stretch with age. You may be at the limit of your adjustment with an old belt.
I might add you may want to buy one or two extras as the companies that make V-belts now only make them in batches with fewer choices as to size over time as the automotive factories stopped using V-belts over thirty years ago.
The only ones they make regularly now are fractional horsepower belts for lawn mowers and household appliances. If a fractional horsepower belt fits size wise it won't work, as it isn't strong enough to last under load. Be sure to buy the belt by part number to get a match.
Big Dave
Larger Dave is offline
post #6 of 6 (permalink) Old Aug 18th, 18, 09:15 AM
Simon
My rebuilt pump was squeaking, I traced it down to the nut that holds the pulley being loose. I don't know if this is your problem but maybe check it and see.
slazisme is offline
