67 Camaro 454 BBC intake clearance. Help! - Team Camaro Tech
post #1 of 12 (permalink) Old Aug 21st, 18, 03:12 PM Thread Starter
Probationer
I have a 67 Camaro with the stock flat hood. I just got my 454 back from the machine shop, and I need an intake. My head's have rectangular ports, and I need to find an intake that will fit with a Holly sniper set atop. The problem I'm finding is that all the intake I'm finding for rectangular ports, are high rise. And I don't believe that will work with my hood. All help is appreciated!
Doug William is offline
post #2 of 12 (permalink) Old Aug 21st, 18, 07:29 PM
Tom Anderson
Re: 67 Camaro 454 BBC intake clearance. Help!
I have 2 of those winters rectangle port intakes and even if you use a drop base air cleaner with a flat hood it's going to be to high. you need to change your hood and let it rock with a nice high rise aluminum intake . I also have a hood clearance issue I wanna ask but I will hold off so you can get more replies
socal_tom is offline
post #3 of 12 (permalink) Old Aug 21st, 18, 08:08 PM
375 horse 396 used a Winters high rise manifold and a Holley carb with a dropped base air cleaner and it fit beneath a flat SS hood. Edelbrock dual plane intakes are no higher than the Winters. You could also use a Victor Jr. single plane intake, but not the Victor intake, as it is too tall.
This all assumes you have the motor sitting where it belongs.
Big Dave
Larger Dave is offline
post #4 of 12 (permalink) Old Aug 21st, 18, 09:44 PM
Tom Anderson
Hey Big Dave the SS hoods are not flat they have a small rise . so what about this Dave do you know is a air gap will fit under a SS hood . I just bought a NOS ZZ383 450 HP 450 TQ engine and they didn't come with intakes . So Big Dave I know your a smart guy on engines so what will work best foe me ?
post #5 of 12 (permalink) Old Aug 22nd, 18, 03:10 AM
kevin
I have a sb sitting on bb frame mounts with a edelbrock victor jr. air gap under a 68 ss hood
I have just enough room to add a 1" spacer if I want
flat tire is online now
post #6 of 12 (permalink) Old Aug 22nd, 18, 06:50 PM
Tom Anderson
Question Kevin why do you run your small block on big block frame stands ? Thanx for the info on the air gap and the SS HOOD
post #7 of 12 (permalink) Old Aug 22nd, 18, 11:13 PM
Probationer
I have to run a 2 inch air cleaner because I have very little clearance. I'm running a 396 on correct bb mounts and frame stands, edelbrock dual plane performer, holley carb, drop base, stock iron heads, SS hood.
There must be a drop base that is more than what I have right now but I have the lowest one that summit sells! Is anyonen sucessfully running this combo with a 3 inch filter?
Taylor Clarke is offline
post #8 of 12 (permalink) Old Aug 23rd, 18, 02:55 AM
kevin
no particular reason other than it works
post #9 of 12 (permalink) Old Aug 23rd, 18, 12:57 PM
Apprentice
Darrell
67 with 427ci BB, Edelbrock RPM manifold, Holley Sniper, and drop base air cleaner all under the stock SS hood. Super tight fit, the wing nut for the air cleaner rubs the new under hood installation pad.
Doubt an air gap manifold will fit, too tall.
One last suggestion, if your body mounts are old and crushed, put new ones in you can gain a half inch of clearance
Fly Low and Avoid the Radar
blowamouse is offline
post #10 of 12 (permalink) Old Aug 23rd, 18, 06:14 PM
Beth
The factory drop base air cleaner used a 3" filter and it was made specifically for a Holley carb :
68 Camaro convertible, 6.0 LQ4 with LS3 heads, Vintage Air, 750 street demon carb, eddy perf rpm, GM hot cam, Hooker headers, 4L80e, 12 bolt, 3.55 gears
NashvilleCat is offline
post #11 of 12 (permalink) Old Aug 24th, 18, 03:51 AM
Greg
pittpens24's Avatar
Be careful with the drop base air cleaners. I personally had a heck of a time trying to figure out how to get an air cleaner to fit under my cowl hood with my 572. After a couple of unsuccessful tries ordering from Summit, I called Edelbrock and Sceptre(they made low profile cold air intakes) to see if either made a low-profile air cleaner with a drop base. I found out from both companies that I needed more element than I had room for as a drop base takes away flow from your filter height by whatever the drop is and as far as the cold air intake, when I gave them my parameters, they said the air gap was too tight and I wouldn't get enough air flow. I know a 572 need more than a 454, but do some homework
'68 Camaro with RS conversion
Moser 9" with 4:11
Tremec T-56 Magnum 6 speed
572 BB - CM Engines
pittpens24 is online now
post #12 of 12 (permalink) Old Jan 12th, 19, 08:46 PM
Apprentice
I'm considering the Sniper for my 68 SS 396/L78 with the flat SS hood.
(Can you clarify), are you using the stock GM drop base, or the Holley drop base?
I'm not sure if I like the Holley drop base as it appears to only drop by about an inch? Also it doesn't have a provision to connect the vent tube.
jimsl78 is offline
