Holley Terminator EFI Inlet manifold space advice - Team Camaro Tech
post #1 of 7 (permalink) Old Aug 23rd, 18, 10:45 PM Thread Starter
Apprentice
Sean
Unhappy Holley Terminator EFI Inlet manifold space advice
Hello to all fellow forum friends.
I have a 1968 SS Camaro, 4 speed, 12 bolt, multi-leaf. My car is in relatively stock condition with engine, suspension, brake & body upgrades. Mainly due to safety reasons.
I purchased a Holley Terminator EFI Stealth for my machine to go on top of a Edelbrock dual-plane Air-Gap manifold. After plenty of research I have come up with the fact to help my car run better, I'll need to install a 1/2" carb spacer.
This will also eliminate having to modify the current dual-plane manifold or to make a purchase for a single-plane manifold.
All that said, my dilemma is that all the online stores that I have made contact with have different ideas with the type of spacer I should use.
Open plenum, clover leaf, super sucker, 4 holes and the list goes on...talk abound confusing.
Please any help will be greatly appreciated.
Sean
SS68 is offline
post #2 of 7 (permalink) Old Aug 24th, 18, 02:44 AM
Re: Holley Terminator EFI Inlet manifold space advice
What are you wanting from the adapter besides making the EFI fit ?
More torque
More top-end HP
Move the HP/TQ curve up or down
But....in all reality, we're talking very small numbers with a 1/2" spacer on an Airgap manifold.
68 Camaro~LSx ~all motor
post #3 of 7 (permalink) Old Aug 24th, 18, 03:45 AM
Vega$69's Avatar
I dont think there is much to be gained with a 1/2 spacer on the air gap intake. It may also create clearance issue air cleaner to hood.
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #4 of 7 (permalink) Old Aug 24th, 18, 07:38 AM
DjD
DjD's Avatar
What is the issue putting the terminator on a dualplane intake?
...Dennis
DjD is offline
post #5 of 7 (permalink) Old Aug 27th, 18, 05:53 PM Thread Starter
Apprentice
Sean
Hey and thanks for all the reply`s.....
The reason for the spacer was that I watched a YouTube video by Engine Master. apologies as I can not remember the chapter.
if you say that the advantages are very small, I guess that I will give the idea a miss. again thank you for the reply`s.
Sean
SS68 is offline
post #6 of 7 (permalink) Old Aug 27th, 18, 07:54 PM
Darin
ilikeike's Avatar
If you have the Air Gap with the milled out notch in the center devide your MAP sensor should be getting a good enough signal from both sides, so you shouldn’t need a spacer.
If it’s a solid divider the MAP only gets signal from one side which can cause tunning issues, like shown on the engine masters video.
1968 Butternut Coupe,
421" Dart SHP block
TKO 600 RR
Dutchman 9" w/3.70 US Gear Lightning r&p
Global West arms
Budnik wheels
ilikeike is offline
post #7 of 7 (permalink) Old Aug 27th, 18, 10:45 PM Thread Starter
Apprentice
Sean
Hi Darin. Thanks for the feedback.
I guess that I will pull the manifold off and crank up the mill.......
Again, thank you for the feedback, greatly appreciated.
Cheers
Sean
SS68 is offline
