BBC Motor Mount Question - Team Camaro Tech
 1Likes
  • 1 Post By Matt 69
post #1 of 13 (permalink) Old Aug 25th, 18, 03:20 AM Thread Starter
Brett
One thing I noticed when I bought this car was these Rocker Arm spherical washers that someone put in between the block and the motor mount, with the intent I assume to raise the engine up about 1/4". With everything together it would be a pain to get them out. But now since I'm in the process of putting the heads back on and the tranny is out, should I go ahead and get those out of there? Put the correct engine mount bolts back in there?
Brett.....
1969 SS 396 X66 - RS Conversion - TKO600 - 3.73 Posi - Paint Code 71-LeMans Blue
Brettallen59 is offline
post #2 of 13 (permalink) Old Aug 25th, 18, 03:32 AM
Re: BBC Motor Mount Question
No time like the present. I'd fix that if it were me.
buenymayor is offline
post #3 of 13 (permalink) Old Aug 25th, 18, 04:16 AM
Matt
Brett, before you take them out, check the clearance between your headers and the steering gear box on the drivers side of the engine compartment. It is not uncommon to "shim" the drivers side motor mount to gain clearance between the header tubes and the steering box. I have mine shimmed up 1/4" for that exact reason. It will not hurt anything and is virtually undetectable. FYI.
flat tire likes this.
12 Bolt 3.55 Posi
461 BBC TKO600
Matt 69 is offline
post #4 of 13 (permalink) Old Aug 25th, 18, 04:49 AM Thread Starter
Brett
And I'm now thinking that it could be the reason that they were installed. My Hedman Hedders barely did fit, so you are correct that it might cause more of an interference issue. I will put the headers back up and evaluate. My main concern was now that I'm installing a Tremec TKO600, I don't want to risk a bad driveline or tranny alignment issue.
Brett......
post #5 of 13 (permalink) Old Aug 25th, 18, 05:31 AM
Vega$69's Avatar
Take them out and use these if you need to shim
https://www.summitracing.com/parts/mor-62535
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #6 of 13 (permalink) Old Aug 25th, 18, 05:41 AM Thread Starter
Brett
Attachment 220981
Great John, I will order them today along with the correct ARP bolts. I think the bolts I picked out on the Summit (HERE) site are long enough. Do you concur?
Brett.....
post #7 of 13 (permalink) Old Aug 25th, 18, 06:28 AM
Vega$69's Avatar
t also looks like you're missing the motor mount plate that goes between the mount and the block.
https://www.summitracing.com/parts/ens-3-1114g
69 Z28(Sold)
(SOLD)
Vega$69 is offline
post #8 of 13 (permalink) Old Aug 25th, 18, 06:31 AM
Jeff
Brett.....
Personally I would remove one of the existing bolts and verify the length required.
Thanks,
Jeff
1968 Camaro
Chevy68 is offline
post #9 of 13 (permalink) Old Aug 25th, 18, 06:47 AM
Matt
Brett, I have the Energy Suspension motor mounts installed WITH the supplied backing plate that John listed and I STILL need to shim my motor mount for additional header clearance. That is what I had to do to get my headers to fit. It doesn't necessarily mean that you will need to do the same. FWIW, I have a TKO 600 installed that I purchased from SST along with their kit. Shimming my motor mount did not effect any of my drive line angles or create any problems with shifting or installation. Again, this is my experience with the above mentioned situation.
12 Bolt 3.55 Posi
461 BBC TKO600
Matt 69 is offline
post #10 of 13 (permalink) Old Aug 25th, 18, 08:44 AM
kevin
Attachment 220981
just asking a ?
what is the difference between the plates you show and what Brett has other than $$$$$
a 1/4" is a 1/4"
flat tire is online now
post #11 of 13 (permalink) Old Aug 25th, 18, 10:09 AM
Vega$69's Avatar
Originally Posted by flat tire View Post
just asking a ?
a 1/4" is a 1/4"
I think the shim plates spread the load more evenly on all three bolts but in reality functions probably the same.
And to me the plates look better. It only money. Haha
69 Z28(Sold)
(SOLD)
Vega$69 is offline
post #12 of 13 (permalink) Old Aug 25th, 18, 01:38 PM Thread Starter
Brett
Kevin, John; You are both right. I need to pull the bolts because they appear to be grade 5 or less. Plus, I have no idea how much thread is in the block. I think I want to replace the bolts for more correct grade/length, and I think it will be easier to install the plates John found rather than trying to position three different washers individually. Maybe not? I do want it right, and since it's not a whole lot more, I can afford it. But I agree that it is not a critical necessity.
Brett.....
post #13 of 13 (permalink) Old Aug 25th, 18, 02:41 PM Thread Starter
Brett
Good Idea. I will do that to determine the max length needed.
Brett....
