Replace frame mounts and motor mounts. - Team Camaro Tech
 5Likes
post #1 of 24 (permalink) Old Aug 25th, 18, 11:56 AM Thread Starter
Hello. My motor mounts are worn and likely the wrong ones (at least I think the frame mounts are wrong—for a big block), so I got a new set of both. The motor mounts are poly (flexible), as I was told they’d work well with what I have. Anyway, I’m a novice, to put it nicely. I don’t have an engine hoist. So any suggestions how I tackle this? Lift up using jack under oil pan?
Mike's69stroker is offline
post #2 of 24 (permalink) Old Aug 25th, 18, 11:58 AM Thread Starter
Oh, and just to clear up what I just said, I have a small block (383). I think the frame mounts are for a big block. The last guy put some washers as spacers to make it work
post #3 of 24 (permalink) Old Aug 25th, 18, 04:12 PM Thread Starter
And so I guess I’m just asking for tips on how to approach this. As far as lifting the engine, maybe try to use a two-by-four with the jack on the balancer?
post #4 of 24 (permalink) Old Aug 25th, 18, 04:39 PM
Vega$69's Avatar
Re: Replace frame mounts and motor mounts.
Originally Posted by Mike's69stroker View Post
And so I guess Iím just asking for tips on how to approach this. As far as lifting the engine, maybe try to use a two-by-four with the jack on the balancer?
yes
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #5 of 24 (permalink) Old Aug 25th, 18, 07:20 PM
Beth
I'm not really following what you want to do.
Are you trying to lift the engine from below and replace the motor mounts and frame stands ?
If so you want to do it one at a time using plywood to protect the the oil pan.
Not exactly easy for a novice. Can be dangerous.
68 Camaro convertible, 6.0 LQ4 with LS3 heads, Vintage Air, 750 street demon carb, eddy perf rpm, GM hot cam, Hooker headers, 4L80e, 12 bolt, 3.55 gears
NashvilleCat is offline
post #6 of 24 (permalink) Old Aug 25th, 18, 10:40 PM
NO don't jack on the balancer. Jack on the oil pan. ( IMHO). Protect the pan like Beth said. Watch the fan shroud, hoses, and distributor when jacking. Only jack enough to free up the mount....Jb
69Z28 likes this.
Beat it to Fit, Paint it to Match!
Johnny B is offline
post #7 of 24 (permalink) Old Aug 26th, 18, 09:56 AM Thread Starter
Yep, the danger is what I’m concerned about, don’t want to lose any fingers. So use some plywood under the oil pan?
Any tips about the bolts? They are hard to get to (not much room for a socket) and I don’t want to strip them
post #8 of 24 (permalink) Old Aug 26th, 18, 11:43 AM Thread Starter
I’m finding now that the frame mount bolts might be a hassle, as the nuts are almost impossible to get to (there’s only a small, perfectly round hole in the subframe). How to get to that bolt?
post #9 of 24 (permalink) Old Aug 26th, 18, 11:44 AM Thread Starter
...nut, I mean
post #10 of 24 (permalink) Old Aug 26th, 18, 12:43 PM
Apprentice
Maybe a wiggler.Been a long time since i had to do mine but i do remember it being a pain in the a##
racer86y is offline
post #11 of 24 (permalink) Old Aug 26th, 18, 01:09 PM
Ratchet with long extension to reach up inside the subframe to get to the nuts.
69 Hugger Orange 396 M20 3:31
BRICO69 is offline
post #12 of 24 (permalink) Old Aug 26th, 18, 01:39 PM
Vega$69's Avatar
That gets them off. The trick is getting them back on. 🤔
yellow69RS likes this.
69 Z28(Sold)
(SOLD)
Vega$69 is offline
post #13 of 24 (permalink) Old Aug 26th, 18, 04:27 PM Thread Starter
Yeah, no kidding.
post #14 of 24 (permalink) Old Aug 31st, 18, 02:12 PM
I never had a problem putting them back on. Use a shallow socket with a long extension. Put some "dum-dum" on the socket and push the nut on to it. This way the nut won't fall off while you have it up inside the subframe.
BRICO69 is offline
post #15 of 24 (permalink) Old Aug 31st, 18, 05:05 PM
scblucam's Avatar
Bolt should be inserted from the bottom, nut on top. Standard structural stuff. Nut comes loose bolt falls off you see a hole. Bolt from the top, nut falls off you see a bolt head and don't know the nut is off.
68 302 M20 - 85 IROC Z
scblucam is offline
