Power to distributor , no spark - Team Camaro Tech
post #1 of 9 (permalink) Old Aug 25th, 18, 10:50 PM Thread Starter
Kevin
I am hoping someone can help me out. I installed new AAW harness in my 67 SB 350 and now in wont start. Prior to installation i had a wire from the battery to a toggle switch and from the switch to the BAT side of cap. Would jump the starter with a screw driver. I would do this just to start every now and then. Now I have the new harness and it won't start.
I installed the new ignition switch with harness and nothing. If I jump the starter it will turn over but won't start. Disconnected the new harness, re-installed quick start set up and if fires right up.
Any ideas? Trying to figure this out before Monday and have to call AAW.
kmarron is offline
post #2 of 9 (permalink) Old Aug 26th, 18, 12:31 AM
Gary
69Z28's Avatar
Re: Power to distributor , no spark
Have you made sure the wires are connected to the block on the rad support behind the battery?
06A 1969 Camaro Z28 711 69 B Black Stripes Console w/tach and gauges
69Z28 is offline
post #3 of 9 (permalink) Old Aug 26th, 18, 02:39 AM
Craig
Are you using a neutral safety switch. With my 5 speed I did not use neutral safety switch. So I had to jumper across the neutral safety switch wires. I have a console so the neutral safety wires are in the console. I can't remember the color but I believe they were purple. I can cr tomorrow or look at your instructions to determine
Agitator is offline
post #4 of 9 (permalink) Old Aug 26th, 18, 05:20 AM
keith
X-77 keith's Avatar
Purple sounds correct for the wire colors.
X-77 keith
X-77 keith is offline
post #5 of 9 (permalink) Old Aug 26th, 18, 07:36 AM
Jeff
yellow69RS's Avatar
Not sure from the description if it won't turn over or won't fire. If not turning over check the purple wire on the small terminal; at the starter closest to block for power woth the key turned all the way to crank. if no power there find NSS connections and test on both sides of switch, if no power there check back of ignition switch. If not firing check power at cap with key on and in crank if no power check at firewall connector then ignition switch.
Jeff
yellow69RS is offline
post #6 of 9 (permalink) Old Aug 26th, 18, 08:08 AM
Vega$69's Avatar
AAW harness has a purple the goes to NSS and from NSS to starter. If no NSS the the purples need to be connected to each other
If switch in start position and it not cranking. Then issues is the purple in not jumped, not to the S terminal on the starter or problem at the switch itself.
If it cranks but doesnít start check to see the is 12v at + side of coil in the run position and also if 12v in the start position.
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #7 of 9 (permalink) Old Aug 26th, 18, 06:29 PM Thread Starter
Kevin
Vegas, that was it. Connected the two purples and it fired right up!
Thank you very much!!
kmarron is offline
post #8 of 9 (permalink) Old Aug 26th, 18, 06:39 PM
Vega$69's Avatar
Sweet.
I love wiring and AAW is my favorite. Iíve installed a dozen or so.
Can do it in my sleep. Haha
69 Z28(Sold)
(SOLD)
Vega$69 is offline
post #9 of 9 (permalink) Old Aug 26th, 18, 07:14 PM
keith
X-77 keith's Avatar
I like AAW too, but the last dash harness I got was missing a wire. It was just never installed. I was scratching my head for days trying to figure it out.
X-77 keith
