Alternator bracket with headers - Team Camaro Tech
post #1 of 6 (permalink) Old Sep 1st, 18, 05:52 PM Thread Starter
Apprentice
Has anyone had luck with alternator brackets on a 327 SBC with headers. The ones I've tried are very flimsy and don't work well with the header bolts. They're nowhere near as solid as the ones used with the original exhaust manifolds.
67327 is offline
post #2 of 6 (permalink) Old Sep 1st, 18, 06:53 PM
keith
X-77 keith's Avatar
Short waterpump?
X-77 keith
X-77 keith is offline
post #3 of 6 (permalink) Old Sep 1st, 18, 07:47 PM Thread Starter
Apprentice
Re: Alternator bracket with headers
Yes, short waterpump.
67327 is offline
post #4 of 6 (permalink) Old Sep 2nd, 18, 05:05 AM
I have used OE bracketry by using a pair of spacers the thickness of the OE manifold minus the header flange, and used heat treated studs with nuts attaching the bracket.
Cast iron pipe works well. Measure OE flange, subtract flange thickness, then this will be the spacer length. Paint and install studs as this event will put bracket at OE dimension.
post #5 of 6 (permalink) Old Sep 2nd, 18, 06:37 AM
Josh
I went with Alan Grove brackets on my 68Z. I have stock heads with Headmann Headers and used the 213L bracket. Good quality but they do come as bare metal so they will need paint or powder coating.
http://www.alangrovecomponents.com/S...Short_Pump.htm
68 Z/28
383, M-20, 8.5 w/ 3.73's
jcihos is offline
post #6 of 6 (permalink) Old Sep 2nd, 18, 07:17 PM Thread Starter
Apprentice
Thanks, I will experiment with both options.
67327 is offline
