Starter - Team Camaro Tech
post #1 of 8 (permalink) Old Sep 3rd, 18, 11:48 AM Thread Starter
Jonathan
Starter
I have a 327 with powerglide and the starter went bad. It was not the original starter. How many teeth should be on the starter gear? The one i took off had 11. The OEM replacement I bought has 9. It’s the starter with two sizes of bolts.
Red6a1 is offline
post #2 of 8 (permalink) Old Sep 3rd, 18, 01:44 PM
Re: Starter
You generally count the teeth on the starter ring attached to the flex plate or the fly wheel, not the starter pinion gear. 153 teeth designates a 10-1/2 inch clutch on a base engine. 168 teeth on the 11 inch clutch fly wheels were used with big blocks and high horse small blocks. You have a base engine 327 (275 horse) which came with a 10-1/2 inch clutch manual or a 153 tooth PG flex plate. As such you use the starter with two bolts side by side as seen in this photo:
The orange colored starter has diagonal bolts to attach it to the block; so it is intended to fit a BBC or a high horse SBC (it will be for a 168 tooth flywheel). Hopefully you have the bolts side by side to match your starter ring or there will be teeth shed and added expense.
The picture below is of a high torque starter used on big blocks and small blocks factory rated at more than 300 horsepower:
Note the long brass tube that is spacing out the distance from the energizing lug at the front of the motor from the solenoid that supplies the power. This is for a 168 tooth flywheel. A base engine starter has a shorter electrical motor so the energizing lug at the front of the motor touches the solenoid directly without the long spacer.
Big Dave
Larger Dave is offline
post #3 of 8 (permalink) Old Sep 3rd, 18, 02:04 PM Thread Starter
Jonathan
It’s the original flywheel. Does it matter how many teeth are on the starter? The bolt holes are straight across with one long and one short bolt.
Red6a1 is offline
post #4 of 8 (permalink) Old Sep 3rd, 18, 04:18 PM
Re: Starter
Originally Posted by Red6a1 View Post
Itís the original flywheel. Does it matter how many teeth are on the starter? The bolt holes are straight across with one long and one short bolt.
With the bolt holes are straight across the starter should fit your PG. But yes the number of teeth on the pinion doers mater as they have to mesh with the ring gear.
Big Dave
post #5 of 8 (permalink) Old Sep 4th, 18, 07:23 PM
scblucam's Avatar
Re: Starter
When I had so much trouble years ago after the 302 was built, once I found one that worked, when it got weak I went to the starter rebuilder and said "REBUILD THIS ONE, NO EXCHANGE".
68 302 M20 - 85 IROC Z
scblucam is offline
post #6 of 8 (permalink) Old Sep 5th, 18, 12:03 PM
keith
X-77 keith's Avatar
Yea, I have a hand full of old steel starter heads laying around . those are the only ones that seem to work for "MY" 302 manual set up.
X-77 keith
X-77 keith is offline
post #7 of 8 (permalink) Old Sep 5th, 18, 12:49 PM
kevin
Re: Starter
probably a good idea to use the original nose cone on your new starter
flat tire is offline
post #8 of 8 (permalink) Old Sep 6th, 18, 09:32 PM
Nick
Re: Starter
put a mini starter on
67 rs/ss 350 original eng,700r4, a/c, tilt, deluxe int,strato bench,Ca.emission,front disk,am/fm,floor clock,17" W/V Ralleys,Toyo T1S 255/40/17, 245/40/17
MRCOOL_RSSS350 is offline
