Header change - Team Camaro Tech
post #1 of 5 (permalink) Old Sep 7th, 18, 09:49 AM Thread Starter
Apprentice
Ross
Send a message via Yahoo to udtoy
Header change
I want to change the headers on my BBC with P/S from Hooker Pro Comp 2457 to a set of Doug's D320. Does anybody know if this change will be a simple bolt in or if the connection to the collector will be different (shorter or longer) and affect the length of my current exhaust setup? Thanks in advance for any insight from the community!
Project 1969 Camaro living on jack stands, 468 BB, 700R4, Hotchkis TVS Suspension, Kore3/C5 discs
udtoy is offline
post #2 of 5 (permalink) Old Sep 7th, 18, 10:01 AM
kevin
Re: Header change
just curious ? why the change
flat tire is online now
post #3 of 5 (permalink) Old Sep 7th, 18, 10:40 AM Thread Starter
Apprentice
Ross
Re: Header change
I had to dimple the 2457 to clear P/S box even though using correct frame and motor mounts for BBC. My research shows the Doug's sit tighter to the block.
udtoy is offline
post #4 of 5 (permalink) Old Sep 7th, 18, 11:24 AM
Re: Header change
You are aware that dimpling the pipes has no effect upon performance? It is only a cosmetic issue.
https://www.motortrendondemand.com/d...ts/0_ujj8a8mw/
Since there isn't a power loss (the gas in dimpled tube changes speed going through the dent, but volume remains constant) I doubt if it is worth the bother or expense.
If you want headers that fit buy a custom made header. Universal fit headers, like off the rack clothes, are designed to almost fit a wide number of car bodies and years, just not well.
Big Dave
Larger Dave is offline
post #5 of 5 (permalink) Old Sep 14th, 18, 03:38 PM Thread Starter
Apprentice
Ross
Re: Header change
Thanks for the input guys. I know that the dimpled primary doesn't affect performance, but if I'm going to make the move to a stainless header, I'd like to avoid dimpling them if possible, so I'm just wondering about the fit of the Doug's, and if anyone knows if there is a difference in the overall length that could change how my exhaust bolts up to them.
udtoy is offline
