69 302 Con Rods - Team Camaro Tech
post #1 of 9 (permalink) Old Sep 12th, 18, 04:37 PM Thread Starter
69 302 Con Rods
Am rebuilding my VO318DZ and con rods have a raised D cast on the cap. Crank is 1178 and has GM 222 on main bearing cap # 4. Can anyone decode these numbers?
max69z/28 is offline
post #2 of 9 (permalink) Old Sep 14th, 18, 05:25 PM
Re: 69 302 Con Rods
Pink rods should have a O on the cap
69z28302 is offline
post #3 of 9 (permalink) Old Sep 14th, 18, 06:55 PM Thread Starter
Re: 69 302 Con Rods
Were pink rods the only ones used on the Z/28 302s? Also am putting it back into the car now and I installed a rebuilt M20 Muncie. Engine is on the motor mounts but still an inch or so between bell housing an tranny flange. Any tricks I can use to bring it together?
post #4 of 9 (permalink) Old Sep 14th, 18, 09:04 PM
Travis
Put the clutch linkage in and depress the clutch and it will slide right in. Another way is to put a ratchet strap on the clutch fork. At the end of the day you have to disengage the clutch.
travisch is offline
post #5 of 9 (permalink) Old Sep 15th, 18, 03:58 AM
Brett
Re: 69 302 Con Rods
Are you sure about this? If that was the case wouldn't the bell housing push away when you would loosen the bolts during a removal ( the clutch is engaged when you take it apart)
Is it possible that the clutch disk is installed backwards causing this?
Brett.....
1969 SS 396 X66 - RS Conversion - TKO600 - 3.73 Posi - Paint Code 71-LeMans Blue
Brettallen59 is offline
post #6 of 9 (permalink) Old Sep 15th, 18, 04:23 AM
keith
X-77 keith's Avatar
Could be mis aligned clutch disk too.
X-77 keith
X-77 keith is offline
post #7 of 9 (permalink) Old Sep 15th, 18, 05:15 AM
Vega$69's Avatar
Re: 69 302 Con Rods
The input shaft is not going into the pilot bearing due to misalignment
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #8 of 9 (permalink) Old Sep 15th, 18, 06:30 AM Thread Starter
Re: 69 302 Con Rods
Thanks for all the help. Clutch and bell housing were aligned and put in at the engine builder's shop by a veteran. Will hook up the clutch and try that first.
post #9 of 9 (permalink) Old Sep 15th, 18, 06:48 AM
Lynn
Re: 69 302 Con Rods
Originally Posted by max69z/28 View Post
Were pink rods the only ones used on the Z/28 302s? ?
Yes. If they were shot peened at one time, the pink paint may be missing. But all the original 69 Z motors had Pink Rods. Should have full floating pins as well. If not, they are not the original rods.
Lynn
bilodeaulynn is offline
