Deeply damaged camshaft bore#1 - Team Camaro Tech
 1Likes
  • 1 Post By 3d cad
post #1 of 8 (permalink) Old Sep 22nd, 18, 09:17 AM Thread Starter
I have a 327 2 bolt main engine that has damage to the #1 camshaft bore caused by a spun cam bearing. The deepest diameter of the damaged camshaft bore is 2.1010Ē. I've took it to several engine shops in southern ca and they all said that the damage is to deep. Is there any shop out there that can fix this? Is it impossible to put a custom metal sleeve into the camshaft bores to be able to fit standard sized camshaft bearings, or just make custom oversized bearings?
johnv805 is offline
post #2 of 8 (permalink) Old Sep 22nd, 18, 10:31 AM
Re: Deeply damaged camshaft bore#1
I presume you are trying to save an original block. Talk to these guys. https://rpmengine.com/ They are a bit north of you i think.
johnv805 likes this.
3d cad is offline
post #3 of 8 (permalink) Old Sep 22nd, 18, 12:24 PM
Vega$69's Avatar
Is there some reason youíre trying to save this block?
May cost more to fix then picking up another block for a couple hundred bucks
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #4 of 8 (permalink) Old Sep 25th, 18, 06:27 AM Thread Starter
It's a numbers matching block.
johnv805 is offline
post #5 of 8 (permalink) Old Sep 25th, 18, 09:49 AM
You can sleeve it but it won't be cheap. In older machinery sleeving is often the only answer. You only need to repair the bad bore, not resleeve the whole cam gallery. Many automotive machine shops can't do general machine work, they perform specialized procedures on specialized machines, many automotive machine shops would be at a loss to make you a bolt turn you an oil pump shaft. try to find a general machine shop and talk to the old pissed off looking guy in the back, he can fix your block.
67 RS/SS 350, M21, 3:70 POSI, Hooker side mount headers, blue dot tail lights. owner since 1974.
327fuelinjected is offline
post #6 of 8 (permalink) Old Sep 25th, 18, 10:03 AM
Now that is funny Jim...and oh so true. Makes me wonder if youíre the old guy. Anyway when that guy is found the biggest obstacle will be convincing him the job is serious. He likely has other old brainstorms laying around awaiting payment.
3d cad is offline
post #7 of 8 (permalink) Old Sep 28th, 18, 01:25 PM Thread Starter
I just picked up my block from QMP racing and they told me that cam journal #1 is 0.080 big and cam journal #2 is 0.012 out of round. The only way to save the block would be to line bore all the cam journals and install a custom oversized camshaft. The block is for a 1967 camaro rs. It’s a 327ci 210 hp block
johnv805 is offline
post #8 of 8 (permalink) Old Sep 28th, 18, 01:37 PM
The only thing of value is the date code. Doubt if you have a partial VIN and it can be restamped if need be. Check some of the larger recycling yards as they index their cores by not only size and year, but date code.
If you positively have to have that block it can be bored to BBC journal size and roller bearings pressed in place.
But it would be cheaper by far to find, and buy a compete used SBC 400 short block out of a seventies Impala or pick-up in your area and just stick on your heads after you bore them for steam holes.
Big Dave
Larger Dave is offline
