396 timing - Team Camaro Tech
post #1 of 3 (permalink) Old Sep 25th, 18, 06:51 AM Thread Starter
ken
Thumbs up 396 timing
I would like to know what are the degrees between #1 tdc and #8 tdc and #4 & #3 & #6 & #5 & #7 & # 2 I believe that the degrees between each cyl should be the same for tdc thanks for info camaro ken
ken5537 is offline
post #2 of 3 (permalink) Old Sep 25th, 18, 06:55 AM
Re: 396 timing
Cylinder firing order is separated by ninety degrees. Seven hundred and twenty degrees of crankshaft rotation to complete one cycle.
Big Dave
Larger Dave is online now
post #3 of 3 (permalink) Old Sep 25th, 18, 08:07 AM Thread Starter
ken
Re: 396 timing
thanks for the quick reply when it is time to get a answer you guys always come thru thanks and have a good day camaro ken
ken5537 is offline
