Looking for cam opinion - Team Camaro Tech
post #1 of 6 (permalink) Old Sep 30th, 18, 09:35 PM Thread Starter
Probationer
383 sbc 4 bolt mains, scat crank, Manley rods, flat top pistons 10.25:1 compression ratio
Edelbrock performer rpm heads
Edelbrock Performer RPM intake that I plan on porting to gasket match
MSD Pro billet with 6al2
1.6 ratio roller rockers
Long tube headers
Tko-600
4.10 gears
I want to use a hydraulic flat tappet camshaft. Mostly street driven. Might spray it with 100-200 shot every once in a blue moon
Sent from my iPhone using Tapatalk
67Camaro383 is offline
post #2 of 6 (permalink) Old Sep 30th, 18, 09:42 PM
Darin
ilikeike's Avatar
Easy,
A matched Edelbrock RPM cam.
Me, I’d call a cam manufacture and put a nice healthy matched roller cam in it for the type of driving I’d be doing.
1968 Butternut Coupe,
421" Dart SHP block
TKO 600 RR
Dutchman 9" w/3.70
Global West arms
Budnik wheels
ilikeike is offline
post #3 of 6 (permalink) Old Oct 3rd, 18, 07:41 PM
Greg
Re: Looking for cam opinion
I loved my Performer RPM cam. But I would highly recommend going roller.
69 Camaro, 3650lbs., 400ci, TH400, Coan 10" converter, 3.50 gear
D1SC, pump gas, street car, Water/Meth injection
1.302 60', 5.956 @ 116.4 Super Sniper EFI 2019
Greg O is offline
post #4 of 6 (permalink) Old Oct 4th, 18, 03:52 AM
kevin
do yourself a favor and go with the roller
flat tire is offline
post #5 of 6 (permalink) Old Oct 4th, 18, 05:22 AM
Matt
I built a 355 that was very similar to your configuration about 10 years ago. I used the LT4 HOT cam with 1.6 ratio rockers and it was a very good running engine. I chose that cam after speaking with the Edelbrock tech after I purchased the RPM heads. As the others have said a roller cam is the way to go; you won't be disappointed.
My Build Thread
350sshugger is offline
post #6 of 6 (permalink) Old Oct 4th, 18, 03:59 PM
Stuck on a FT cam ?....old school Comp 292 might fit the bill.
68 Camaro~LSx ~all motor
