Holley Carb ID - Team Camaro Tech
post #1 of 11 (permalink) Old Oct 3rd, 18, 09:24 AM Thread Starter
Holley Carb ID
Can anyone ID this carb? It's supposed to be a Holley 950cfm, but I don't recognize the cross over tube unless it was an off road truck carb. I don't have the list number. Obviously someone tried to make it "pretty"...
A friend owes me some money and wants to give me a couple of carbs towards it. I usually don't pay more than $75 for a used Holley unless it's something special. I'm trying to do a favor, but I don't want to mess around with a knock off Holley or something.
Thanks.
'69 SS396 X66 L34 08D M21 BS
460ci Gen VI 9.75:1 AED 950 carb
Semper Fi!
HawkX66 is offline
post #2 of 11 (permalink) Old Oct 3rd, 18, 11:28 AM
Vega$69's Avatar
Re: Holley Carb ID
https://www.google.com/search?q=holl...daYow66EzCJ_M:
https://rover.ebay.com/rover/0/0/0?m...2F401603239444
Looks like the vent hoop was added
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #3 of 11 (permalink) Old Oct 3rd, 18, 11:52 AM Thread Starter
Re: Holley Carb ID
That makes sense. I'm thinking it was something someone built out of an HP body or something. The blocks seem like they aren't Holley. No vacuum ports. Also, I think the body is on backwards. I'm planning on stripping the paint or repainting it to my liking and seeing if I can use it on my new motor if it's any good. He's shipping it to me.
Semper Fi!
HawkX66 is offline
post #4 of 11 (permalink) Old Nov 3rd, 18, 01:55 PM
Rufas
Re: Holley Carb ID
Hard to find the LIST number when some chuckle head destroys the carb by hacking the air horn off it. It MIGHT be that the tops of the metering blocks may have an 'L' number, or, LIST. Let me know when and if you find a number on the blocks, I have the complete Holley LIST number catalogue, I used to work at Holley. It also looks like it started life as a Marine carb, for a boat, they use that sort of bowl vent crossover.
dave ray is offline
post #5 of 11 (permalink) Old Nov 3rd, 18, 02:23 PM
Re: Holley Carb ID
Looks like a Barry Grant.
rodent4 is offline
post #6 of 11 (permalink) Old Nov 3rd, 18, 02:39 PM
Re: Holley Carb ID
If it is a Holley it is a member of the HP series though I suspect it could be a Proform knock off or a Quick Fuel just as easily. Billet aluminum metering plates where invented by Barry Grant but every body (including Holley) offers them now. Fuel bowls appeared to be just painted, not anodized a different color, the way the manufacturers do it.
Measure the venturi (narrowest part of the throat out side the boosters) and butterfly size to determine cfm. The original Holley 950 cfm (list 3916-1S) was a three barrel with the secondaries dumping into a big oval, instead of two separate bores); but they recast the 1050 cfm and 950 cfm 4150 series to have their own carb main body.
https://www.ebay.com/i/262767834877?chn=ps
vs a new Holley 950 cfm four barrel
https://www.holley.com/products/fuel...EaAq-8EALw_wcB
Holley will recoat your cab with the original gold Iridited color finish for a fee (something like a $100 if I remember correctly).
Big Dave
Larger Dave is offline
post #7 of 11 (permalink) Old Nov 5th, 18, 05:57 AM Thread Starter
Re: Holley Carb ID
Nothing has been hacked off.
Big Dave
Thanks Dave and rodent. After doing a ton of research (looking at pics to compare), I think either one of you could be correct. I think it's an HP type, but one that has been customized. You can see ghost marks from where the original numbers should have been. There's a "D" that I can read on the metering block. Maybe AED? The black appears to be original. It's inside the metering blocks and on the body and looks pro done. The guy I got it from had the bowls powder coated. I'm going to change that...
It's definitely a 4150. I rebuilt it this weekend and put it on my 69. I installed 31cc accelerator diaphragms, 31 squirters, and 78/80 jets. The car runs awesome and I'm able to get my AFR gauge looking decent around 14, but I feel like I'm leaving a lot on the table. Even though I had problems setting that 850cfm up, the car seemed to have a lot more nut. It could be because it's just so smooth now though.
I'll take some measurements Dave and see what I come up with. The butterflies are 180 and have been drilled.
Semper Fi!
HawkX66 is offline
post #8 of 11 (permalink) Old Nov 6th, 18, 05:14 AM
Kevin
Re: Holley Carb ID
Is it going on a small block? If so, 950 CFM is quite a large flow for it. It will most likely run poorly and/or lousy gas mileage. I have found that for a stock or slightly modified small block, 600 to 650 CFM is a good choice for drive ability and fuel mileage.
Check the jet sizes; they may also be way too much for a small block.
When I was young and stupid, I always thought that bigger was better. Never bothered to read up on CFM sizes, and what worked best for an engines CID size and breathing capability. Now that I'm older (but still carry stupid traits at times), I read and take the advice of the manufacturers recommendations, along with hot rodding tricks and advice.
If you do try it on any engine that is not set up to breathe and accept 950 CFM's worth of air, don't blame the carb if it performs poorly. It will most likely be too much for the engine.
Never argue with an idiot; they'll only drag you down to their level, then beat you with experience.
bucko is offline
post #9 of 11 (permalink) Old Nov 6th, 18, 05:19 AM Thread Starter
Re: Holley Carb ID
If you do try it, don't blame the carb if it performs poorly. It will most likely be too much for the engine.
No. Big block.
Semper Fi!
HawkX66 is offline
post #10 of 11 (permalink) Old Nov 6th, 18, 05:02 PM
Morgan
Re: Holley Carb ID
The blocks look like the Holley billet ones I have, they were all black, I sanded them down the outside, they look like yours, main body is an Hp, proform or add, measure the bore size of the baseplate as well should be an 850 base with the 180 throttle plates, 172 is the 750
69 Copo 9560 ZL-1 automatic [email protected], 1.95 on f70-14 polyglas F.AS.T. Race June 2016
69 Copo 9560 ZL-1 4spd [email protected] 1.93 60ft on F70/14
PSMCDR 2014
71LS6 vette [email protected] PSMCDR 2012 SOLD
1971ls6 is offline
post #11 of 11 (permalink) Old Nov 7th, 18, 05:05 AM Thread Starter
Re: Holley Carb ID
Thanks Jeff. Once I get back down to my house this weekend, I'll measure the bores. The base plate does have 180 plates.
Here are a few better pics of when I rebuilt it last weekend.
Knurled idle adjustment screws and the "D".
Semper Fi!
HawkX66 is offline
