air cleaner element rotating. - Team Camaro Tech
post #1 of 3 (permalink) Old Oct 3rd, 18, 08:41 PM Thread Starter
I replaced an older air cleaner filter with a new Spectre, using the existing cover and base. After driving it twice, I've notice that the assembly is rotating counter clockwise each time. The cover has a decal that was over the Spectre name on the filter. Both are still aligned but 1/4 turn off from where I'd put it.
Is this just a case of not tightening down the nut enough? Or is something else going on?
AlamocitySS is offline
post #2 of 3 (permalink) Old Oct 3rd, 18, 08:44 PM
Steven
stamatisg1977's Avatar
This usually happens when replacing the filter with one that is slightly shorter in height than the previous. U can put a thick washer under the butterfly nut to take up the slack or shorten the rod that it screws on to
69 Frost Green Camaro
LS3 with TSP stage 3 cam
Tremec TKO 600
Ridetech rear 4-Link
Follow my journey here:
stamatisg1977 is offline
post #3 of 3 (permalink) Old Oct 3rd, 18, 08:50 PM Thread Starter
Ok, thanks. I was concerned that maybe the filter itself was not allowing air to pass through properly.
