Engine camaro 69 - Team Camaro Tech
post #1 of 10 (permalink) Old Oct 9th, 18, 06:21 AM Thread Starter
Apprentice
MickaŽl
Question Engine camaro 69
Hello, I appear my name is MickaŽl and I live in France.
I possess a camaro 69 and I am spirit to restore the engine.
It is one 3970010 010 020 bellhousing 010 cam gear 4 bolts 4.030 in boron, he is of 1973. I raised the thickness of the walls of cylinder: 0.200 in min face pushed piston 0.106 in min between cylinders
My first question is: what may I make of my block? I shall have wished one l48 rťplica or one 383 stroker hi torq.
Knowing that I owe the rťalťsť in 4.040 min.
By assuming that my block is too low, I give myself the ways to buy a block DART SHP 4.125 2 PC to make my possible stroker 400 this.
Let us assume that I change everything. Shall I have to buy a new engine assembled at your home? (Skip white performance or others)
It loses me a little and I wished to have your notices.
Thank you really a lot.
Cordially MickaŽl
Labelcrosoft is offline
post #2 of 10 (permalink) Old Oct 9th, 18, 06:34 AM
Vega$69's Avatar
Re: Engine camaro 69
MickaŽl
Welcome it's nice to have you.
1st do NOT buy an engine from Skip White. Bad reputation.
If you decide to buy a new Engine I suggest GM Performance or Blueprint Engines.
There is no reason you can not rebuild the block you have to 355 cubic inches or with a stroker rotating assembly to a 383.
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #3 of 10 (permalink) Old Oct 9th, 18, 07:12 AM Thread Starter
Apprentice
MickaŽl
First of all thank you for your answer, made I shall be afraid of paying an usineur to redo all the flatnesses complete of the block then rťalťsage with plate of couple which I should buy so that the rotary set which shall suit on him to be limited in the end by his performance or of his life expectancy.
I do not have the same ease as you, with the distance, the orders cost dear.
Shall I have to not bang in 1000 in 1 blows?
I wish to do that in the settled of art but that one only one time.
post #4 of 10 (permalink) Old Oct 9th, 18, 07:19 AM
Vega$69's Avatar
usineur - French
Machinist - English
Yes you should take the advice of a good usineur.,
Most of the larger US suppliers have good experience shipping to Europe. Summit Racing and Jegs
Vega$69 is offline
post #5 of 10 (permalink) Old Oct 9th, 18, 08:16 AM Thread Starter
Apprentice
MickaŽl
Forgive I of my Englishman
Thus I do not need to worry about the thickness of the walls of cylinder?
Financially that reassures me.
post #6 of 10 (permalink) Old Oct 9th, 18, 08:30 AM
Vega$69's Avatar
Your English is much better than my French.
Yes your block should be ok
Vega$69 is offline
post #7 of 10 (permalink) Old Oct 9th, 18, 08:49 AM Thread Starter
Apprentice
MickaŽl
With French good luck same I I am sad
A config "hi perf" old school would be cool. I possess a crankshaft 3932442 had it risen on them l48? I can find heads however a big work will have to be made, I let at you look https://www.leboncoin.fr/vi/1503528091 . 3947041 is a good number or then turn to 3927186 ?
post #8 of 10 (permalink) Old Oct 9th, 18, 10:33 AM
Nick
those are good heads most were 1.94 some came with 2.02 valves on the 350 hp Corvette
67 rs/ss 350 original eng,700r4, a/c, tilt, deluxe int,strato bench,Ca.emission,front disk,am/fm,floor clock,17" W/V Ralleys,Toyo T1S 255/40/17, 245/40/17
MRCOOL_RSSS350 is offline
post #9 of 10 (permalink) Old Oct 9th, 18, 11:47 AM
Vega$69's Avatar
Those are good heads however the cost to machine and rebuild may be more than the cost of new aluminum heads which will perform better.
Vega$69 is offline
post #10 of 10 (permalink) Old Oct 10th, 18, 08:52 AM Thread Starter
Apprentice
MickaŽl
I am soon going to see them.
The work to be made by the machiniste consists in: replacement guides and valve seats as well as flatness?
I shall prepare them I even (porting )
