Solid roller vs hyd - Team Camaro Tech
 4Likes
  • 1 Post By satz28
  • 1 Post By Vega
  • 2 Post By Larger Dave
post #1 of 9 (permalink) Old Oct 21st, 18, 11:28 AM Thread Starter
Solid roller vs hyd
I tried to copy Dave’s post from the thread on vacuum here but its over my head or thumbs...... anyway i was reading on another site how some guys were turning to street solid rollers to mitigate the issues with the beehives. Is that rational?
3d cad is offline
post #2 of 9 (permalink) Old Oct 21st, 18, 11:47 AM
Re: Solid roller vs hyd
Maybe due to the weight difference of hyd Vs. solid lifters ?
Over my head also, but IF/WHEN I go back to a solid, I'll be calling a buddy at CamMotion
68 Camaro~LSx ~all motor
post #3 of 9 (permalink) Old Oct 21st, 18, 12:37 PM
The reason solid rollers got a bad rap on the street is they require oil to the rollers. In a drag car it is oiled by windage (splash lubrication). On the street to survive you have to use a self oiling solid roller invented by Ed Iskedarian. I use his Red Zone brand to give him credit and my cash to keep him innovating, though Comp has copied Ed's design and sells theirs for less.
A solid will rev higher than a hydraulic roller because it is lighter. To keep the valve closed at high RPM you have to increase seat pressure which you can do with a hydraulic roller; but at high RPM, the lifter wants to fly off of the ramp of the cam lobe. To keep control of the valve, and prevent floating lifters you need a lot more open pressure than a hydraulic tappet can withstand (usually they collapse if open load exceeds 350 pounds of pressure).
Big Dave
Larger Dave is online now
post #4 of 9 (permalink) Old Oct 21st, 18, 01:52 PM Thread Starter
Dave, assume the grind is a decent hot street grind and not a balls to the wall race grind, does a solid roller offer advantages/disadvantages with regard to a hydraulic.
Doug, i heard a bit of this from CamMotion too. I didnt know whether it was marketing or sound engineering though.
3d cad is offline
post #5 of 9 (permalink) Old Oct 21st, 18, 03:37 PM
The hydraulic cam will be low to no maintenance depending upon how aggressive the ramps are. It will limit the RPM of the motor because you can not run a stiff enough spring with a hydraulic lifter to spin it above 5,800 to 6,400 RPM depending upon the weight of your valves. If you have enough displacement to make the level of torque that you are satisfied with, then the choice is going with the hydraulic.
If you have a 302 you need the revs to make any power at all. Which is why I love watching weekend warriors trying to back in their Z/28 Camaro into a parking space at the car show while stalling it two or three times doing so in front of a large crowd. With the same DZ 302 and a hydraulic cam out of a 283 he could back it in without any drama, but it wouldn't make a lot more power than a standard 275 horse 327; despite having better induction and heads.
Drivability is the difference between a race car and a street car.
post #6 of 9 (permalink) Old Oct 21st, 18, 05:14 PM
True statement.
post #7 of 9 (permalink) Old Oct 21st, 18, 05:16 PM
Rob
satz28's Avatar
Anybody that kill’s their 302Z’s backing into a sparking spot, shouldn’t be driving the car.
68rs406 likes this.
Rob
Sold 6-1-2014 after owning the car for 18+ years
69 Z-28 X-77 HO * DZ Put away * M20 * 4.10
406 CI * CC XR274R 236/[email protected] 564/570 110 LSA/106 ICL * Brodix IK 200
475 HP, 495# tor
Street Tires, Full Exhaust Sep 07 -12.68 @ 113 MPH * Street Tires, Open Headers Oct 08 - 12.65 @ 116.2 MPH
satz28 is offline
post #8 of 9 (permalink) Old Oct 21st, 18, 06:09 PM
Vega$69's Avatar
The 69Z I bought new was my daily driver for 5 plus years. I actually had a trailer hitch on it and towed a 16 ft outboard ski boat. Took it to the mountains to play in the snow and everything else. I don't recall ever STALLING it backing into parking
satz28 likes this.
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #9 of 9 (permalink) Old Oct 21st, 18, 06:35 PM
I believe ya John, and Rob; but I mentioned a weekend warrior who bought this Z to recover his long lost youth, though he probably never had a hot car before. He drives his Lexus or BMW mini van most of the time (not used to a manual). I see them all the time at the local car show.
You have to admit with three pedals trying to back in at idle the Z doesn't exactly overpower with it's 30/30 cam at low RPM. He probably couldn't heel toe it if his life depended upon it.
Like Rob said he doesn't deserve to own one but he has more than enough cash to buy one.
Big Dave
satz28 and Vega$69 like this.
