3935438 Casting 4 Bolt Main - What is your opinion? - Team Camaro Tech
post #1 of 4 (permalink) Old Oct 27th, 18, 12:54 PM Thread Starter
Brett
3935439 Casting 4 Bolt Main - What is your opinion?
I found a freshly machined 3935439 casting 4-bolt main 427 block bored out to a 496. The seller says the deck was machined so there are no stamping left. New cam/crank bearings. with bearing caps and studs with nuts. Seller wants $600. Does this sound worth investigating for a purchase? I could go look at it tomorrow and inspect for quality. Maybe offer an amount less ($500 cash). What do you all think? Can this be a two piece rear seal or a one piece rear seal?
Brett......
Rockets Up In 2020!
Brettallen59 is offline
post #2 of 4 (permalink) Old Oct 27th, 18, 01:26 PM
Re: 3935438 Casting 4 Bolt Main - What is your opinion?
3935439 would make it a 1968-'69 427 Mark IV two piece rear main seal block. To make it a four bolt block; four bolt main caps were added (which can be done by any machinist after the fact), and oil cooler provisions were machined into the block for Corvette applications.
Those cooler line holes will look like this if the pipe plugs were removed for cleaning the block:
Is worth a premium? In my opinion no.
Final honing (sizing the bore) is done to match the pistons, not having custom pistons turned down to fit your existing block. So a bare block over bored already is useless without eight to ten (two spares in case you drp a valve or two) new pistons to fill those bored holes.
Big Dave
Larger Dave is online now
post #3 of 4 (permalink) Old Oct 27th, 18, 02:11 PM Thread Starter
Brett
Ooopps Dave, I was wrong. It IS a 9. 3935439 casting number. Sorry for the typo. So these did not come as a 4-bolt? That is good info, although it looks okay in the pic as a decent upgrade. I'm sorry I misunderstood. I now see this block was available as both a 2-bolt and a 4-bolt block.
Brett.....
Rockets Up In 2020!
post #4 of 4 (permalink) Old Oct 27th, 18, 02:23 PM
All of the blocks were cast the same. Whether it got four bolt main caps or two bolt main caps was determined by a work order given to the machinist that converted the raw casting int a finished block. Two or four was a mater of what cap they put on the block. Two bolts were cheaper so Chevy made more of them.
Big Dave
