Valve cover gasket installation to glue or not to glue? - Team Camaro Tech
 11Likes
post #1 of 20 (permalink) Old Oct 28th, 18, 07:20 PM Thread Starter
Tim
Back in the day I used this Aviation form a gasket on valve covers
What is the preferred method nowadays? Im using cork fel-pro gaskets and some OER chrome stock GM repro valve covers
1967 RS/SS Coupe, Factory A/C, 2nd owner, original paint -Taho Turquoise 3 Spd on the floor, bench seat, fold down rear seat
1967 RS Convertible Factory A/C, PS, PB PG 327
Niblet is offline
post #2 of 20 (permalink) Old Oct 28th, 18, 07:39 PM
Chris
Re: Valve cover gasket installation to glue or not to glue?
Unless you're going for that all original look, get some Felpro blue silicone gaskets. The mounting holes have crush sleeves and they can be removed and replaced over and over with no leaks.
eville and Niblet like this.
'69 Z/28, Lemans Blue/White Stripes, DZ302, Tremec Magnum, 4.10, Procar Elite Seats,
Custom Upholstery, Dynatech headers, 17" VWW V45's, 235/45, 275/40, C5 Front Brakes
ctcz28 is offline
post #3 of 20 (permalink) Old Oct 29th, 18, 04:56 AM
kevin
if using studs for the valve cover no need to glue, especially if using the gaskets mentioned above
cork gaskets and bolts, I used 4 pieces of sewing thread and a dab of glue in the center of each end
makes cleanup a lot easier when replacing gaskets
flat tire is offline
post #4 of 20 (permalink) Old Oct 29th, 18, 07:53 AM Thread Starter
Tim
I'm not visualizing this,,,,sorry but it sounds like a decent idea
Niblet is offline
post #5 of 20 (permalink) Old Oct 29th, 18, 07:57 AM
Ed
Permatex Copper Gasket Maker but be conservative with it, no need to over do it.
ZEN357 is offline
post #6 of 20 (permalink) Old Oct 29th, 18, 09:01 AM
kevin
Loading media
Loading...
$25.99
post #7 of 20 (permalink) Old Oct 29th, 18, 09:11 AM Thread Starter
Tim
Yes I just ordered some of those in the Stainless variety,,I meant the trick with the thread and glue...
Niblet is offline
post #8 of 20 (permalink) Old Oct 29th, 18, 09:22 AM
kevin
place the valve cover open end up place gasket on VC use sewing thread to tie the gasket in places in vc and gasket
add a dab of glue at each end
post #9 of 20 (permalink) Old Oct 29th, 18, 07:57 PM
Rufas
I also do studs for most everything, including oil pans, valve covers, but, I do it a bit differently than expensive studs. I use Allen set screws, they are available just about everywhere, hardware stores, mcmaster.com, and, they work, not expensive, and, they have an Allen socket to insert and remove them. Simple nuts work, along with flat and lock washers if desired.
In working on all sorts of motorcycles as well, I changed my view of gasket sealer preparations. The cases of most motorcycles do not use paper, nor rubber gaskets, they use a sealer compound that sets soft, and is easily removed. It also works excellent with gaskets as well. in fact, it works so well, it is the compound used on intake manifold gaskets around water jackets, a bead of sealer, wither blue, gray, whatever. This stuff is made by the company that makes it for all the motorcycle manufacturers, Three-Bond, and the number is 1194, or whatever they call it now. Cleans off with acetone, or lacquer thinner, easily worked with, a little on a gasket goes a long, long way.
It also works on metal to metal, plastics to metals, and other situations where a good self sealing compound is needed. It is NOT workable for sealing beads on the front and rear areas of intake manifolds to eliminate the rubber end seals, nor for exhaust system heat levels.
jimnecci and Niblet like this.
dave ray is offline
post #10 of 20 (permalink) Old Oct 30th, 18, 04:04 AM
kevin
Niblet likes this.
post #11 of 20 (permalink) Old Oct 30th, 18, 04:54 AM
Vega$69's Avatar
Valve cover gaskets leak most often not because of the gasket material used or the use or not of sealer.
They leak because they are over tightened. Particularly with the stamped steel chrome and painted covers.
The studs are a good choice and will keep the gaskets in place when installing. I would follow the instructions supplied by the gasket supplier. When I use sealer I like this one.
Niblet likes this.
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #12 of 20 (permalink) Old Oct 30th, 18, 08:07 AM Thread Starter
Tim
All good ideas, I went with the ARP Studs
Niblet is offline
post #13 of 20 (permalink) Old Oct 30th, 18, 08:24 AM
Honestly get the silicon felpro with the steel core too. Itís like a belt and suspenders. No fail.
1968 that started life and a 6 banger with a PG. Now it's a 350 with a TKO600, Moser 12 bolt, Speedtech LCA/UCA, ATS Tall Spindles, Hotchkis Springs, Forgeline ZX3P, C5 (Kore3) brakes with other cool stuff from Ron Davis, Vintage Air and soon to be Terminator EFI.
eville is offline
post #14 of 20 (permalink) Old Oct 30th, 18, 08:26 AM Thread Starter
Tim
I did and got the ARP studs,,seems like a good combo
Niblet is offline
post #15 of 20 (permalink) Old Oct 30th, 18, 08:34 AM
Vega$69's Avatar
If you use the felpro silicon do not apply any sealer.
Edit. IMO
69 Z28(Sold)
(SOLD)
Vega$69 is offline
