SS 396 Fuel Return Line Question - Team Camaro Tech
 8Likes
  • 2 Post By rp930
  • 1 Post By Garfields Maro
  • 1 Post By HawkX66
  • 3 Post By Mike_S
post #1 of 11 (permalink) Old Nov 23rd, 18, 06:22 AM Thread Starter
Brett
I'm in the process of getting my engine back together. I had purchased an AC fuel filter with a return line that I had on the car Now I am discovering that it was actually for the 350 SS. In the Factory Assembly Manual, for the SS 396, it shows a fuel line that has a fuel junction block that splits off into two lines for a Holley dual feed carb, but there is no mention of the return line. My car has an original return line. If I get the 396 version, it would work with my Holley, but I don't know how to plump in the filter and the return line. Here are both SS set ups, the 350 and the 396:
This one on eBay is for a 396 BBC. It does not show a filter or a return line:
This one is for a 350 (The one I have now):
Can you guys help me clear this up so I can put the correct fuel connections on this car? The first one I bought was actually for a Vette (or it could just be for small blocks), bringing the fuel line up short of the water pump, not actually correct for the 396's. I guess it's not really that big of deal, as I'm not building a 100% correct original.....
Thanks,
Brett......
Rockets Up In 2020!
Brettallen59 is offline
post #2 of 11 (permalink) Old Nov 23rd, 18, 07:07 AM
Rick
Re: SS 396 Fuel Return Line Question
The 396 version you show is only for 375 hp engines and 427 COPOís. The lower hp 396ís use the return line with a Q-jet carb if Iím not mistaken. The Holley used in those two engines donít use a return line.
HawkX66 and Garfields Maro like this.
69 COPO clone, 461" BBC 11.25:1 Compression
840 Rec Heads (2.25/1.88) AED 850 HO carb
Orig Exhaust Manifolds
Straub (Clay Smith) cam, 288/300 .600/.569 109.
TH400, 3500 stall, 4.11 12 bolt posi
rp930 is online now
post #3 of 11 (permalink) Old Nov 23rd, 18, 11:01 AM
kevin
my 68 396/375 never had a return line, unless one of the first two owners did away with it
flat tire is online now
post #4 of 11 (permalink) Old Nov 24th, 18, 10:12 PM
Garth
Return lines began in the 69 model year and were used with quadrajet carbs. L35 or L34 396's , L48 350 and the LM1 350 all used quadrajets (with return line). Holley equipped cars (L78,Z28) didn't have a return line.
I'm no expert Brett, but I think the first engine (L34) is correct on the fuel line/filter set-up...1967 - 1969 Camaro engines
Here's what HBC has to offer...1969 Camaro Fuel Line Kit From Fuel Pump To Carburetor 3 Pieces 396-325 HP 396-350 HP OE Material - 1967, 1968, 1969 Camaro Parts - NOS, Rare, Reproduction Camaro Parts for your Restoration
BRICO69 likes this.
Garfields Maro is offline
post #5 of 11 (permalink) Old Nov 27th, 18, 07:25 AM
You needed this page for the 396 w/ return line. Holley or Quadrabog can both use the return line. Only one line goes from the filter to the carb or, in the case of the Holley dual feed, a splitter.
Like was mentioned, only the L34/L35 396 (for big blocks) had the return line.
AIM L34 pages_Page_05 by Dave H, on Flickr
Front_Engine by Dave H, on Flickr
Alternator_water_pump_pulley_pic_copy by Dave H, on Flickr
Garfields Maro likes this.
'69 SS396 X66 L34 08D M21 BS
460ci Gen VI 9.75:1 AED 950 carb
Semper Fi!
HawkX66 is offline
post #6 of 11 (permalink) Old Nov 27th, 18, 03:43 PM
Garth
"Quadrabog"...lol They were known as "Quadrapuke" where I'm from.lol
HawkX66 likes this.
post #7 of 11 (permalink) Old Nov 27th, 18, 05:06 PM Thread Starter
Brett
Great. Thanks Dave. Thanks for the pics! I did find that page you posted. The pics will help out for sure. Would the filter still function properly if I had it in the horizontal position, instead of vertical?
Brett......
Rockets Up In 2020!
post #8 of 11 (permalink) Old Nov 28th, 18, 12:26 PM
Brett......
You're welcome. I'm sure it would work, but why? That's an expensive filter to replace. The only reason for leaving it in that location and that style of filter is for originality IMO. Changing it from vertical to horizontal would stick out like a sore thumb.
Semper Fi!
HawkX66 is offline
post #9 of 11 (permalink) Old Nov 28th, 18, 04:09 PM Thread Starter
Brett
No, your right. It would be wrong to go that far into making it the way it was and then go change it. You persuaded me to go with it the way it was.
Brett.....
Rockets Up In 2020!
post #10 of 11 (permalink) Old Nov 28th, 18, 05:30 PM
Michael
When setup correctly, they do perform good.
69Z28, HawkX66 and Garfields Maro like this.
67 LOS SS/RS L35 Hardtop - Original w/UOIT
67 NOR SS/RS L35 Convertible - Restored
Mike_S is offline
post #11 of 11 (permalink) Old Nov 29th, 18, 07:22 AM
Rick
Talking Re: SS 396 Fuel Return Line Question
We called them Quadraflush.
Rick
Sam 15 is offline
