fuel pressure not stable - Team Camaro Tech
post #1 of 8 (permalink) Old Nov 27th, 18, 06:41 PM Thread Starter
ken
hi I have a 427 with a mechanical fuel pump it shows 6psi when it is cold but as the engine warms up the pressure slowly drops to almost 0. is this a vapor lock problem-fuel pressure gauge-gas cap venting can I add a electric fuel pump by the gas tank to aid the machinal fuel pump? the fuel line is single I put a temp sensor on the input line it reads about 78 deg f thanks for looking ken
ken5537 is offline
post #2 of 8 (permalink) Old Nov 28th, 18, 04:24 AM
kevin
Re: fuel pressure not stable
if the engine runs as it should when warm, I would first start with the gauge
flat tire is offline
post #3 of 8 (permalink) Old Nov 28th, 18, 04:37 AM
Agree, replace gauge and/or spray the gauge with a can of keyboard duster, its CO2.
You could also remove gas cap when the gauge reads close to zero and observe if pressure comes back up.
And you should be able to suck on cap in testing vent, and it is a one-way valve - pressure in, no pressure out.
As Kevin suggests, if engine runs as good when warm as it does cold, throw away the gauge - problem solved.
A short test of mechanical pump is see if it will fill a qt bottle in about 15-20 seconds, +/- 10, maybe 15, at idle speed.
Mech pumps only provide a volume of fuel, not pressure.
Doing a good job is like peeing in your dark pants you get a warm feeling, but nobody notices
post #4 of 8 (permalink) Old Nov 28th, 18, 05:55 PM Thread Starter
ken
THANKS FOR THE INFO IT SURE IS NICE HAVE ANSWERS THAT WILL HELP SOLVE PROBLEMS WITH OLDER CAMAROS KEN
ken5537 is offline
post #5 of 8 (permalink) Old Nov 28th, 18, 06:34 PM
Bill
bill3337's Avatar
I had a similar issue with a fluid filled Russell pressure gauge. As the engine warms the pressure in the gauge builds as there was no vent. I drilled a tiny hole in mine and it's been fine, but according to Russel, you shouldn't use a fluid filled gauge under the hood. Switch to a dry one will likely solve your problem.
bill3337 is offline
post #6 of 8 (permalink) Old Nov 29th, 18, 06:51 AM
Where is your gauge mounted? If it's under the hood, don't trust the pressure reading when it's hot. I ended up biting the bullet and getting a fuel isolator and moving a gauge inside the car so I could rely on the reading.
'69 SS396 X66 L34 08D M21 BS
460ci Gen VI 9.75:1 AED 950 carb
Semper Fi!
HawkX66 is offline
post #7 of 8 (permalink) Old Dec 1st, 18, 03:30 PM
I had the non fluid filled one and it bounced all over the place. I then switched to the fluid filled one and it reads low when the engine is hot. If you really want it to be accurate you need to get the gauge out of the engine compartment. I was going to get an electric fuel pressure gauge but they are really expensive and I don't like having them mounted on the cowl, so i just let it alone for now. Good luck.
Dave69Z is offline
post #8 of 8 (permalink) Old Dec 2nd, 18, 09:57 AM
Yes, with a mech pump, gauge will bounce because of the stroke of mech pump.
