Edelbrock Throttle & kickdown bracket? - Team Camaro Tech
post #1 of 6 (permalink) Old Dec 1st, 18, 10:18 PM Thread Starter
Anyone running the Edelbrock Performer intake and the 1406 carb?
67 327 2 brl, powerglide
You using the stock throttle linkage and kickdown as is or a Edelbrock bracket?
SoCal805 is online now
post #2 of 6 (permalink) Old Dec 2nd, 18, 12:08 AM
Smile Re: Edelbrock Throttle & kickdown bracket?
I use this bracket for my 700r4 TV cable.https://www.jegs.com/i/JEGS/555/157313/10002/-1 My 1405 Edelbrock carburetor uses the stock throttle rod.
TJS69 is offline
post #3 of 6 (permalink) Old Dec 2nd, 18, 07:03 AM
RDW
Bob
I used the stock set up with my 327 and TH350
67 Camaro coupe 327 automatic
78 RS Camaro 350 automatic (sold)
RDW is offline
post #4 of 6 (permalink) Old Dec 2nd, 18, 08:45 AM
Nick
you have to use stock throttle linkage and kick down you can't use a bracket
67 rs/ss 350 original eng,700r4, a/c, tilt, deluxe int,strato bench,Ca.emission,front disk,am/fm,floor clock,17" W/V Ralleys,Toyo T1S 255/40/17, 245/40/17
MRCOOL_RSSS350 is offline
post #5 of 6 (permalink) Old Dec 2nd, 18, 10:20 AM Thread Starter
Thanks, thought I read stock works, clears everything. Thanks for confirming
post #6 of 6 (permalink) Old Dec 3rd, 18, 06:20 AM
Kevin
When a previous owner removed the powerglide and replaced it with the TH350 in my 67, they left the kick down uninstalled. I had to buy a bracket similar to the link in post number 2. The stock throttle linkage was fine, but the transmission kickdown needed a "holder" in order to allow for its cable to pull forward when the throttle was "mashed".
Maybe that same previous owner removed (for whatever reason) a stock bracket that was installed for three speeds (used in 68 and above)?
Never argue with an idiot; they'll only drag you down to their level, then beat you with experience.
bucko is offline
