Low sitting engine - Team Camaro Tech
post #1 of 3 (permalink) Old Dec 4th, 18, 04:23 PM Thread Starter
Bruce
Low sitting engine
Finishing a complete restoration on a 69 as a SS clone for a client. Original 327 replaced with a 69 350 with 350 engine mounts and kept the 327 frame mounts. Installed the shroud to have the 17" fan hitting the bottom of the shroud. I need another inch to clear. The question is, shim the engine mounts or replace the frame mounts to raise the engine for clearance. Replacing the frame mounts at this stage is a real pain. The research I did before on the engine mount situation was not including this issue as the correct 327 engine mounts were the same as the 350. . . .I ordered them from 4 companies!! What do you guys think?
The Camaro Guy is offline
post #2 of 3 (permalink) Old Dec 4th, 18, 04:56 PM
Vega$69's Avatar
Re: Low sitting engine
Change frame towers. Do it the right way
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #3 of 3 (permalink) Old Dec 6th, 18, 11:05 AM
Robert
Smaller fan? Larger shroud? Depends on how "original" of a look the owner is going for. Unfortunately changing the frame mounts is not the easiest but that is what I would do.
AKXtreme
69 Camaro L48 SS350
M20 4spd
akxtreme is offline
