new 4 brl carb & kick down problem - Team Camaro Tech
post #1 of 3 (permalink) Old Dec 8th, 18, 06:51 PM Thread Starter
swapped from the 2 brl Rodchester to Edelbrock 4 brl.
The kick down rod does not have enough adjustment to extend the kick down rod connected to carburetor to allow full throttle open. The linkage of the kick down stops before full throttle. Blades only open 3/4 full
Accelerator linkage is no problem
I need about 1/4" to 1/2" more
Is there a longer rod available (slotted in front & threaded in rear)?
SoCal805 is online now
post #2 of 3 (permalink) Old Dec 8th, 18, 07:13 PM Thread Starter
Re: new 4 brl carb & kick down problem
...on further review apparently the kick down rod is 2 brl and 4 brl specific. The later being 2" longer (14") than the 2 brl (12")
I assume I can drive by just manually shifting down to low till the new one arrives
post #3 of 3 (permalink) Old Dec 9th, 18, 06:22 AM
True, 4-bbl vs 2-bbl linkage are different in length.
No, WOT upshift is controlled by linkage, partial throttle upshift is controlled by intake vacuum and vacuum modulator.
Trans will shift fine without kickdown hooked up.
Doing a good job is like peeing in your dark pants … you get a warm feeling, but nobody notices
Everett#2390 is online now
