Vac canister broken so do I upgrade? - Team Camaro Tech
post #1 of 3 (permalink) Old Dec 17th, 18, 02:51 PM Thread Starter
Apprentice
Went to check the timing this evening I read the timing and was sitting at 28° at idle. Thought that was high and checked the vac suction and I pulled air through. Someone must have set the timing high as they knew the canister was leaking.
I was going to change the dizzy to electronic anyway so might do it now. I'm looking at the petronix billet piece. Any thoughts on the petronix distributor? Maybe HEI?
Going on a 68 327 Camaro if that makes any difference.
Cheers
BenF88 is offline
post #2 of 3 (permalink) Old Dec 17th, 18, 08:40 PM
Chris
Re: Vac canister broken so do I upgrade?
Some good guidance from Dave Ray and others in this thread:
https://www.camaros.net/forums/33-ca...running-3.html
'69 Z/28, Lemans Blue/White Stripes, DZ302, Tremec Magnum, 4.10, Procar Elite Seats,
Custom Upholstery, Dynatech headers, 17" VWW V45's, 235/45, 275/40, C5 Front Brakes
ctcz28 is offline
post #3 of 3 (permalink) Old Dec 21st, 18, 03:19 PM Thread Starter
Apprentice
Thank you. Helpful thread. I have to ordered a pertronix billet distributor with ignitor 2, flame thrower 2 coil, and 8mm leads.
BenF88 is offline
