Dip stick tube removal 454 mark 4 - Team Camaro Tech
post #1 of 7 (permalink) Old Dec 18th, 18, 07:59 PM Thread Starter
Jon
I'm removing the stock exhaust manifolds in my 67 Camaro to make way for headers. But I'm having troubles navigating the dipstick tube.
It's a 454 mark IV and the tube goes into the stock oil pan. Doesn't appear to be any bolts, but looks like it's just a slide-n-fit operation.
How do I remove the dipstick tube? Do I simply pull it out? It's very snug and tugging at it is met with a lot of resistance. I don't want to break anything.
Thanks in advance for any tips, or information.
Heavychevy67 is offline
post #2 of 7 (permalink) Old Dec 18th, 18, 09:10 PM
keith
X-77 keith's Avatar
Mine always had a bracket going to one of the manifold/ header bolts. Double check that before pulling too much.
X-77 keith
X-77 keith is offline
post #3 of 7 (permalink) Old Dec 19th, 18, 04:20 AM
Re: Dip stick tube removal 454 mark 4
Once you remove any bracket bolt from the head/exhaust manifold it should just slide out, but I have seen them with a clip. They can be pretty seized in there depending on condition also.
'69 SS396 X66 L34 08D M21 BS
460ci Gen VI 9.75:1 AED 950 carb
Semper Fi!
HawkX66 is offline
post #4 of 7 (permalink) Old Dec 19th, 18, 07:16 AM
bob
I've seen them on SBC be very tight where an expanding ID puller (with a slide hammer) was needed after the tube broke off while trying to remove it.
good luck....
bob15 is online now
post #5 of 7 (permalink) Old Dec 19th, 18, 11:26 AM
kevin
I know you don't want to hear this. but the easiest way is to remove the pan and use a punch
find a tapered punch and insert into the tube as far as you can without forcing . then grab it with vise grips and start pulling and slight twisting at the same time. if you can safely, use a little heat on the block NOT THE TUBE
flat tire is offline
post #6 of 7 (permalink) Old Dec 19th, 18, 01:41 PM
Michael
I removed the tube on my 67 L35 last year for its first time since '67 and it took a good tug once the manifold bolt was removed.
The rubber O-ring that seals the tube in the oil pan gets rock hard with age and causes binding. I performed a few gentle circular movements and then gave it a very firm straight-up pull and it came out. Wear gloves because when it suddenly releases it can cut.
67 LOS SS/RS L35 Hardtop - Original w/UOIT
67 NOR SS/RS L35 Convertible - Restored
Mike_S is offline
post #7 of 7 (permalink) Old Dec 20th, 18, 01:43 AM Thread Starter
Jon
Thank you for all of your tips and info.
After unbolting the dip stick bracket on the manifold, I gave the tube a tug and it eventually came out of the pan.
